Old 08-09-2015, 08:41 PM   #1
Erik1972
2" 1972 C10 Coil Spring Lift Suggestions?
Looking for a nice cheap 2" lift to make my black beauty look that much meaner. 1972 C10, 1/2 Ton, LongBox, coil springs. Any recommendations guys?
Erik1972 is offline   Reply With Quote
Old 08-10-2015, 03:02 AM   #2
andrewmp6
Re: 2" 1972 C10 Coil Spring Lift Suggestions?
The front you can run 1 ton springs or do the 88-98 lift spindle swap.The rear i have no clue on if you have coils but if its leafs you can get a longer shackle.
Old 08-10-2015, 08:26 AM   #3
ERASER5
ERASER5's Avatar
First you have to flip the shackle. On the these trucks at least, the shackle hold the spring above the shackle. For 1" or 2" a block is best for leaf springs. No change in spring rate or binding.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-10-2015, 01:31 PM   #4
Erik1972
Coils in both the rear, and front.
Old 08-10-2015, 01:34 PM   #5
Erik1972
I was maybe thinking of doing something more along the lines of blocks, as there is coils in the front and back.
Old 08-10-2015, 03:44 PM   #6
BigDan3131
BigDan3131's Avatar
Blocks would be unstable for anything other than normal street driving. Is this a 2 wheel drive truck?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 08-10-2015, 11:16 PM   #7
andrewmp6
With rear coils you need taller springs,You can't use a block to lift it in the rear the axle is on top of the truck arm a block would lower it.
Old 08-11-2015, 12:12 PM   #8
Erik1972
Yes, it's a 1972 1/2 ton longbox C10 (RWD)
