Old 06-20-2019, 12:08 AM   #1
Captainfab
60-66 Nut
'60-'62 Front Shock Bracket
In the past week or so, I have had 2 people email me and ask if I make a front upper shock bracket for the '60-'62 frames. Apparently when swapping the '73-'87 front suspension under a '60-'62 frame, there is an interference with the top of the shocks, the upper control arm shaft and the stock shock bracket. Not having done this to a '60-'62 frame, I am at a loss. I searched and did not find any mention of this issue here on the forum. Have members here experienced this issue? And is there a need for a shock bracket to correct this issue?
Old 06-20-2019, 08:18 AM   #2
LVPhotos
LVPhotos's Avatar
Re: '60-'62 Front Shock Bracket
For reference, CPT. From Porterbuilt kit on my 62
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 06-20-2019, 06:57 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I think I'm on at least 4 years gone by and still haven't done my newer front end swap on my 62 frame.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-20-2019, 08:27 PM   #4
LVPhotos
LVPhotos's Avatar
I got a pic of a 57 chevy pickup with a Volare clip torsion bar with bags. Remind me I will dig up. The volare clip was done in 80s to do what my 62 did stock.
Old 07-15-2019, 02:29 PM   #5
Bugeyev8
Bugeyev8's Avatar
the stock location of the stock bracket is at the wrong angle for the late model x member n lca...I just moved the stock bracket on my frame..mine are just tacked in at the moment
Bugeyev8 is offline   Reply With Quote
Old 07-16-2019, 03:15 PM   #6
notsolo
notsolo's Avatar
I used a thin cut off wheel removed stock bracket and bolted it back on in new location.
notsolo is offline   Reply With Quote
Old 07-17-2019, 04:12 PM   #7
forestb
forestb's Avatar
x2
forestb is offline   Reply With Quote
Old 07-21-2019, 01:21 AM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
That's what I did on my 1960 as well. I removed the stock bracket with a new Dremel cut off wheel, moved it back several inches until everything fit correctly, drilled new holes and bolted it back on with grade 8 bolts. It's been in place for over 10 years now working perfectly.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
