07-05-2019, 10:08 PM | #26 |
Re: I need help getting my trucks engine running!!
I will check for 12v to the distributor next
'68 Chevy K20 '72 Chevy K20 - Smokin' Ochre '08 Mercury Grand Marquis - Daily driver/ Parts fetcher Ohh uh, I didn't have time to fix everything... |
07-07-2019, 10:39 PM | #27 |
So I installed my new carb yesterday. I poured gas down the fuel line untill the filter was full and she stopped taking more gas. I tried to fire up the truck and she wouldn't go. At first she cranked and sounded really good like it would go. It fired up and ran for a couple seconds then died. I poured some more gas in the fuel line and tried a few more times but it would just turn over but wouldnt fire. I checked and I do have 12v power to the distributor with the key on. So not sure where to go next with it.
My uncle has worked on old trucks for a long time. I usually try to figure stuff out on my own but I asked him to come down and see if he can help me figure out what's missing. Thanks guys for all your help thus far. I certainly know a lot more than when I started. If anyone has any other ideas of what else to check please let me know. I'll update with how me and my uncle make out
07-07-2019, 10:56 PM | #28 |
Are you sure the fuel pump is working. Pull the fuel line off the carb and crank it over to see if you are getting fuel.
67 short bed step side build |
07-10-2019, 09:55 AM | #29 |
So I finally got the truck running! When my uncle came down yesterday we traced back and found the problem... the sending unit was clogged! I had blown out the rest of the fuel lines but didn't think to check the sending unit. Cleaned it out and when we put it all back together she fired right up! Thanks again to everyone who responded, I learned a lot from all your replies and now thanks to your knowledge and help there is one more old chevy truck up and running! Lots more work to do ahead of me but I couldn't be happier with this progress. You guys are awesome. Thanks again
07-10-2019, 10:53 AM | #30 |
Good work figuring it out. Now you need to throw on a fuel pressure regulator set to 5.5.psi to keep the Edelbrock from flooding.
72 C10 lwb fleetside -stock 350/350 combo |
07-10-2019, 11:05 AM | #31 |
Proprietor of Dale's Corner
I'm glad you got it figured out.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
07-12-2019, 11:41 AM | #32 |
Thanks for that info, this will be my next step. Ordered the Edelbrock unit
07-13-2019, 02:10 AM | #33 | |
Carter M6120 https://www.summitracing.com/parts/crt-m6120/overview/ or M2468 A bit pricier, but this is a higher volume pump. I run this pump on my performance SBCs running Holley carbs. https://www.summitracing.com/parts/crt-m2468/overview/
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
07-13-2019, 09:47 PM | #34 | |
07-14-2019, 05:41 PM | #35 | |
The top two are definitely tapered seat plugs but the bottom one does not look the same to me. Time for new plugs anyhow. Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
07-15-2019, 11:33 AM | #36 |
Get the Edelbrock 1721 fuel pump. I'm using it with my 1406 and it works great. Just a little pricey, but made to work with their carbs.
07-15-2019, 12:53 PM | #37 |
Second that - my set up and it works great
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
07-16-2019, 05:07 AM | #38 |
Thanks Guys. I bought a Carter M4685 mechanical pump... the listing says it runs to a max of 7psi but a bunch of reviews said it worked really well with an Edelbrock carb. Going to try that out and hopefully it will work good
07-16-2019, 05:17 AM | #39 |
In the meantime here is a couple pics of the truck all cleaned up. Really loving that ochre colour!
Sorry about the tire covers
07-16-2019, 05:19 AM | #40 |
Pic 2
07-16-2019, 06:02 PM | #41 |
Nice looking rig. Which seats are you running?
07-17-2019, 08:28 PM | #42 |
Thanks!
Theyre some type of generic bucket seats that came in the truck. No idea what they came out of. Ill upload a pic- sorry about the messy interior this was when I just bought the truck. Theyre OK for now, eventually I would like to install a bench seat from an early 90s GM truck
07-17-2019, 08:31 PM | #43 |
Thanks for the suggestion. All the plugs I pulled were tapered seat, the picture isnt great but the one plug had some oil on it when I pulled it making it look different from the others. All plugs have since been replaced with new ones
07-20-2019, 11:07 AM | #44 |
New fuel pump is installed. Truck fired right up and is running great! Thanks so much for all the help guys
07-20-2019, 11:29 AM | #45 |
Congratulations!! It must feel good
07-20-2019, 07:51 PM | #46 |
Congrats!!!
07-20-2019, 09:14 PM | #47 |
Congratulations! Happy Motoring.
