05-05-2016, 06:54 AM | #26 |
Re: 67-72 winch bumpers
I've built a lot of bumpers over the years. But now I want to build one to look more like the manufactured ones like Warn and Ramsey offered. I have a truck body fab shop that does what I don't have equipment for, like break work. I don't think they have a way to make a curved (form) c-channel. Does anyone have suggestions for where that could get done? I have another design in mind if I can't replicate the store-bought design. I think that first one shown on Lawman's GMC is a Ramsey bumper.
05-05-2016, 12:30 PM | #27 | |
White K20 |
05-05-2016, 04:55 PM | #28 |
6>8 Plugless........
Here's mine. RLC fab made it for me.
http://www.rlcweldfab.com/collections/chevy-bumpers The winch goes behind the license plate and can be accessed from the plate on top if need be.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-05-2016, 10:06 PM | #29 |
home made. I cut the frame horns off so that the upright portion of the push bar which are large L brackets of 3/8" plate runs 10"s down the frame rail and is sandwhiched between the frame and the front spring mounts.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
05-05-2016, 10:30 PM | #30 |
BlahBlahBlah
That's a really nice burly looking set of bumpers on that GMC
… … … … … … … … ... … … … … … … … … … … … Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 |
05-06-2016, 10:57 AM | #31 | |
Nice work!
White K20 |
05-06-2016, 01:37 PM | #32 |
The upright main L brackets are 3/8" which is overkill but is what I had laying around. The main face is 1/4" plate comprised of 3 main sections broke to shape. The anchor points are 3/8" that run through to the back of the main beams. And there is an actual reinforced winch box that sits behind the main face so the winch does not mount to the actual pumper face. Everything is gusseted as well.
On the rear, the box protectors on the side are load bearing. I'll snap some pics later
05-06-2016, 03:18 PM | #33 |
Here's mine I put on my 70 Burb it was a PTO winch, I had filled the area in with polished diamond plate....
http://www.stovebolt.com/gallery/cox_randy_1970.html I had made a crank handle for it by hand, it was more for looks but you could hand crank it if you dare LOL..
1964 BBC 402 4x4 Last edited by RANDY COX; 05-06-2016 at 03:20 PM. Reason: added wording |
05-07-2016, 09:49 AM | #34 |
I used round or square tube stock for maximum strength. But, that limits to only angles. I would angle back from frame rails, then cap the top and ends (angle cut to align with side of fender) with diamond plate. I pie-cut at the frame rails, place an 8" cinder block at the center, hood a come-along to both ends, crank it in, and weld. Then weld the one piece diamond plate on top. I uses 2 x 6 mounted vertical. This time, if I use pipe, I'll do 4" pipe using the same method. My first bumpers were straight 4" tube. Did the trick and gave low resistance when run aground off of inclines. I'm going to talk to the truck body place to see if they have a way, or somewhere to send out, to form c-channel to recreate a manufactured (Warn) winch bumper look. I'll see what's up, then decide. I really like the tube idea but am thinking a Warn-like bumper will match the wrap-around Barten bumper on the rear. If I do the tube I'll do a tube rear
05-08-2016, 01:17 AM | #35 |
Love it!!!
How did you go about bending the hoops for the headlights? Looks pretty thick, 3/8ths? |
09-30-2018, 06:23 PM | #36 |
Here is a rough cardboard mock up of what I'm going to with mine. Going to have ½" plate mounting brackets extending off the frame rails. Then my winch mounting plate will be welded to those. Then I plan on designing it to have a bit of a rake angled towards the ground for better approach angle and sleeker look. All the playing besides the face plate will be 3/16" and the face plate probably 1/4 or 5/16. Should be a pretty rigid SOB
10-01-2018, 11:20 AM | #37 |
10-05-2018, 07:16 PM | #38 |
Winch bumper i made for warn 8274 winch
