Old 01-20-2024, 10:37 PM   #1176
Getter-Done
Getter-Done's Avatar
Re: 67 GMC super custom build
Originally Posted by zicc1835 View Post
not anymore
84 Chevy K-20
Old 01-21-2024, 11:04 AM   #1177
IronCanine
I'm trying....
IronCanine's Avatar
Originally Posted by chewychevy67 View Post
Yep I only have 1 subscriber lol.
4 now. You're blowing up. I like being in on something early.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 01-21-2024, 11:52 AM   #1178
raggedjim
raggedjim's Avatar
Oh come on! Tried to find your youtube page but came up with a video of a doctor pulling a snake out of a woman's ear!
Found it! Tailgate mod is one of my favorites!
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 01-22-2024, 01:02 PM   #1179
Tip70
Tip70's Avatar
i also subbed!
1970 C/10 LWB
build thread:
https://67-72chevytrucks.com/vboard/...d.php?t=847860
IG- Tip70
Tip70 is offline   Reply With Quote
Old 02-07-2024, 03:03 PM   #1180
70STOVEBOLT
70STOVEBOLT's Avatar
Rod, how did you swap the needle on your tach? I would like the needle on my tach to match my speedo and fuel gauge like that.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Coming soon: EFI
2015 Silverado 1500 LS 4.3/6L80/3.23
70STOVEBOLT is offline   Reply With Quote
Old 02-07-2024, 06:23 PM   #1181
chewychevy67
I actually didn't change anything. It's a mechanical tachometer just like a speedometer The electrical tach that most use is different inside. I'm not sure if the needles could be swapped .
chewychevy67 is offline   Reply With Quote
Old 02-07-2024, 08:34 PM   #1182
70STOVEBOLT
Interesting. I wonder if there was an application that used a mechanical tach with HEI.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Coming soon: EFI
Old 02-08-2024, 12:36 AM   #1183
chewychevy67
You could get it on 60s and 70s corvettes I believe. There are definitely hei distributors with the tach drive available. The reason I went with tach drive/mechanical tach is because I was worried that the 60's transistor ignition I used would not be accurate with a electronic tach. I know some 69 camaros came with this ignition factory and used mechanical tachometers so that's why I did this on my truck but hei should be more accurate.
Old 02-08-2024, 09:36 AM   #1184
70STOVEBOLT
Thanks for the info!
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Coming soon: EFI
Old 02-13-2024, 03:56 PM   #1185
chewychevy67
Well I did a bit more work on this headlight switch. I soldered the tabs from the reo stat tothe existing terminals on the switch so the stock plug can be used just as it was factory. This does work nice but I find that it dims to quickly between full on and 50%. Like there is no sweet spot of the dimmed light and barely legible. I'm not sure I'm going to keep this on the truck. I might just keep the old bulbs and be done. I spent too much time for a undesirable outcome here.
Old 02-23-2024, 11:32 PM   #1186
chewychevy67
So I'm starting to work on engine bay wiring and the a/c. Got the heater hoses ran like the manual says with all the proper clamps on. But I can't seem to figure out why they pointed the top heater core hose directly at the POA valve hard line . I can not get it so it doesn't rub any way possible. Hmm.
Old 02-23-2024, 11:42 PM   #1187
chewychevy67
I could do this. It still rubs slightly but less stress on the heater core. But doesn't look like the factory would have done this really.
Old 02-24-2024, 02:11 PM   #1188
chewychevy67
It's really getting full Under here. Pretty much everything is mocked up now and ready to come apart except the instant air that pontiac used in 68 . I'm not sure if I'm going to be able to fit it in. Running a vacuum line to it is proving hard to run. Not many vacuum sources on a 67 327 and I've used all of them. I'll have to think about it for a few days before I start to disassemble and get ready Togo back to the body shop.
Old 02-26-2024, 05:04 PM   #1189
chewychevy67
Quite blizzard like outside here today so I stayed home from work and did some more fun work. I got my cooling lines all finished up from the transmission to the cooler. I hated thinking about doing this. I just didn't want to screw it up. Turned out very nicely! But I'm having a problem with my aftermarket 4 core rad rubber mounts. It's like there too thick and holding my rad up 1/2 inch. Hope nos ones or original used ones fix this.
Old 02-26-2024, 08:17 PM   #1190
70STOVEBOLT
Lines look nice! Is that stock radiator? New aftermarket rubbers?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Coming soon: EFI
Old 02-26-2024, 08:50 PM   #1191
chewychevy67
It's my original re-cored. Everything is original except the rubbers. It it almost like they are too thick. Yes new aftermarket rubbers. I probably got them from lmc about 8 years ago.
Old 02-27-2024, 07:58 AM   #1192
chewychevy67
So I found a picture of lmc pads vs originals here. Just as I suspected lmc stuff is garbage. Looks like I'll be looking for a set of originals.
Old 02-27-2024, 07:48 PM   #1193
zicc1835
zicc1835's Avatar
thanks for the followup ....interesting
zicc1835 is offline   Reply With Quote
Old 02-27-2024, 09:56 PM   #1194
72 tigger
72 tigger's Avatar
Good progress!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 03-01-2024, 02:06 PM   #1195
chewychevy67
Well today I finished routing my ac duct hoses and the last under dash stuff. Now I just have to finish the power to the seats and heaters. So the ducting I ordered as a kit from lmc at the same time I ordered the rad rubbers was also crappy. It is so hard that you can't shape it. I was almost going to give up on the dual hoses to the center vent but then I ordered new ducts from old air products and wow you pay a bit more but they took me 20 minutes and they all fit like they are supposed to.i also thought about using new defrost vents because the original ones I thought might be brittle fromthe Sun and heat over the years but again the aftermarket ones wouldn't sit nicely in the recessed area of the dash. Go figure. Always original parts when possible.
Old 03-02-2024, 11:23 PM   #1196
chewychevy67
Well I did get the shroud in and the clutch fan in. My fan blades stick out the back of the shroud only 1/4 inch. It's a nos clutch and same parts that came in the truck so this must be how it was from factory in 67. This clutch is specific to 65-67 327 trucks that have the cast iron pulley because the cast pulley has a thicker mounting base than the 68-72 stamped pulley.
Old 03-26-2024, 05:54 PM   #1197
chewychevy67
Well I got my original style fan blade today and now it's half in half out like its supposed to be!
Old 03-28-2024, 01:07 PM   #1198
Shifty One
Shifty One's Avatar
You, sir, have all the groovies....
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 03-31-2024, 05:57 PM   #1199
chewychevy67
I am really close to disassembly now. I drilled the holesfor the vacuum Hose retainerson the Inner fender and decided to mount the breaker for the power accessories on the firewall closer to the power source which will be the starter battery terminal as the 60s impala used. I just have to remake this harness and the forward light and alternator harness' now. I may do those once the truck is painted and assembled.
Old 04-02-2024, 08:28 PM   #1200
chewychevy67
So today i got my new 4 row rad mounts and they were the same as the others. So off to the beltsander I went to reshape them. I took a quarter inch off all 4 of them. Now they fit like they are supposed to. Still very snug but not feel like going crush the radiator edge.
