Old 01-10-2020, 11:26 AM   #1
corvieman
Cheyenne won't start! till I
Howdy, Problem with Starting the cheyenne! when I push the steering wheel down, few millimeters the engine will start?? can You fix it that the spell is gone? and the steering wheel stays down?
corvieman is offline   Reply With Quote
Old 01-11-2020, 07:48 AM   #2
Re: Cheyenne won't start! till I
Sounds like the adjustment for the steering lock in the ignition switch cylinder might be off or the neutral safety switch adjustment/wiring. I have not heard of it ever before myself though.
Old 01-11-2020, 11:43 AM   #3
sweetk30
sweetk30's Avatar
tilt steering ? if so it could be real loose and need to be taken apart and fixed . very common problem on these style of steering columns .
also the ignition power switch is on the top of the column under the dash . it is moved via the long steel rod inside the column and the key lock switch . the ignition switch is slotted for fine adjustment and some times can be out of adjustment .
1 of these 2 or both together is your problem . this info is for 1994 and older saginaw style columns used by a few makers of vehicles like gm and older jeeps .
here is a pic of the switch thats more than likely out of adjustment . note the 2 slotted holes on the metal mounting bracket .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-12-2020, 04:39 AM   #4
corvieman
Thanks! I'm going to see if this the problem. �� is it also possible that this issue is also is the problem that my daylights and my blinkers won't work?
Old 01-12-2020, 06:51 AM   #5
corvieman
Dearest, I have found the problem! it was the screws of the ignition lock house of the steering column they! were loose.
By the way the head lights still won't work?? and when the hazard lights are one! and I push the headlight button on! they stop working?
only full green turn light indicators stay on! also when I turn the lever to the right or left the 4 turn lights goes on??
