07-14-2017, 08:25 AM | #1 |
Tow Hitch
Hi all,
Truck is finished and the next project on the table top is possibly a 13-14' canned ham camper or a large teardrop trailer/sleeper. Generally the 13'-14' weight in at 1500 lbs. and a teardrop is at 800-1000 lbs. based on what I'm reading. Do any of the members have suggestion or brand or brand of hitch they are using. I have a 1960 GMC Wideside (fleetside) stock with a 305 V-6 and 4 speed hydramatic. From searching the 67-72 site I came across this hitch, but was a bit hesitant, because I was unsure if the width of the rear frame was the same as a 1964-66. https://www.amazon.com/Reese-Towpowe...ulti-Fit+Hitch Thanks, Jake
http://s1299.photobucket.com/user/jb...23904108567829 |
07-14-2017, 09:27 AM | #2 |
Re: Tow Hitch
60-72 C10 Chassis should be the same. I know a lot use 67-72 hidden hitches on 64-66 trucks also.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
07-14-2017, 09:33 AM | #3 |
Re: Tow Hitch
thank you
07-14-2017, 10:02 AM | #4 |
Re: Tow Hitch
Curt
07-14-2017, 01:29 PM | #5 |
Re: Tow Hitch
Frame width is NOT the same 60-66. Get the proper hitch or buy an adjustable one. I bought an adjustable Reese hitch at one of the local chain stores, fixed the size, and then welded it up solid. Nice, quality hitch for $129, I think.
07-14-2017, 03:17 PM | #6 |
Re: Tow Hitch
thx
07-15-2017, 11:29 AM | #7 |
Re: Tow Hitch
63-72 frame width is the same, rarely do they go that far back (63-66). Hidden hitches are great just buy one like the one from CPP like I did, works great on my 65.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
07-15-2017, 01:22 PM | #8 |
Re: Tow Hitch
Ok will check, CPP, I did not k ow they made them.
07-15-2017, 11:36 PM | #9 |
Re: Tow Hitch
You will need a universal hitch like this
https://www.etrailer.com/RV-and-Camp...SABEgK4H_D_BwE Here's an old thread where something similar was used, unfortunately the photos are gone http://67-72chevytrucks.com/vboard/s...d.php?t=390504 Last edited by jweb; 07-15-2017 at 11:41 PM. |
07-16-2017, 11:19 AM | #10 |
Re: Tow Hitch
i used curt mfg. model 13028,perfect hitch,perfect fit.no universal make it work
fabricating.when installed all you see is the receiver square tube under the bumper.i should mention my truck is a 66 short fleet |
07-16-2017, 11:20 AM | #11 |
Re: Tow Hitch
Your 60 GMC won't be able to use those intended for 67-72.
The 60-62 frames are 8" wider than the 63-72. You will probably need the one iWeb posted or a custom one made.
07-18-2017, 02:00 PM | #12 |
Re: Tow Hitch
Could you post pics when you get the trailer?
07-18-2017, 02:21 PM | #13 |
Re: Tow Hitch
That part will be a while,......but will post.
07-18-2017, 03:20 PM | #14 |
Re: Tow Hitch
The reason I bought my '64 suburban was to tow our vintage trailer. Since I haven't touched the suburban in a year, I decided to build a hitch for my '51 using a hitch similar to the one in my link above. I towed the trailer for the first time last month to a vintage trailer rally.
07-18-2017, 04:28 PM | #15 |
Re: Tow Hitch
Beautiful!
02-01-2021, 10:04 AM | #16 |
Re: Tow Hitch
I lucked out and located a ACAR 44" adjustable hitch locally through Facebook Market place for $100. SWEET. Now All I need is the camper......
02-03-2021, 08:51 PM | #17 |
Re: Tow Hitch
Good Score!!!!!!
