01-10-2023, 08:08 PM | #1 |
My 1970 C10 CST build thread
Hi, I've been on here for awhile. This last weekend I bought a 1970 C10 CST in pretty good shape.. It is a V8 307 with a column shift 3 speed.
I'll be working on it little by little, so I wanted to document it here... I'm not sure how to insert pics so as soon as I figure that out, I'll post some.
Eric Hutchins 1970 Chevy C10 CST Last edited by k7elh; 01-10-2023 at 08:22 PM. Reason: adding picture |
01-10-2023, 08:22 PM | #2 |
Re: My 1970 C10 CST build thread
Eric Hutchins 1970 Chevy C10 CST |
01-11-2023, 11:30 AM | #3 |
Looks like a great start! I'll try to help you with posting pictures. When you are adding text to a post scroll down and you'll see the "manage attachments" button. When you click on that it will open up a new page that gives you the option to select up to 5 pictures. After you select the pictures click the "upload" button off to the right side. When that's done you can close that window with the button at the bottom. Then you'll be back to the first page where you can select "preview post" and "submit reply" buttons. Hope this helps.
Brian
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
01-18-2023, 01:23 AM | #4 | |
I'll send a message to the admin and see if they can help.
