10-05-2011, 12:49 PM | #101 |
landarts
Re: Fixrupr
Still have the cab and box to paint. Taking a few days off , some painting will resume next week.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
10-05-2011, 01:02 PM | #102 |
Re: Fixrupr
The hood n everything thurned out nice!! Can't wait to see this thing.together
Posted via Mobile Device |
10-05-2011, 04:12 PM | #103 |
Still plays with trucks
Re: Fixrupr
The pieces turned out nice. Keep up the great work.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
10-05-2011, 05:34 PM | #104 |
Re: Fixrupr
i dont know what you guys are talking about the valdez doesnt need any help haha she is all done and race ready hahaha
VALDEZ 1971 C10 LWB 350/350 http://67-72chevytrucks.com/vboard/s...d.php?t=400327 |
10-09-2011, 11:09 AM | #105 |
landarts
Re: Fixrupr
Well getting ready to get back on the paint job. Items to do to finish the job.
Items to paint
10-20-2011, 03:31 PM | #106 |
landarts
Re: Fixrupr
Well finally back to finishing the paint job. Got everything out of the garage and pulled the bed in on its stand. Finishing up a little wet sanding on the inner bed rails that are to get the paint also. Everything below inside the bed will get Raptor liner in black.
Here a shot of me getting it ready, will shot later this afternoon or lunch time on Friday. Needed to get the temperature up a little in the shop for painting.
10-20-2011, 08:37 PM | #107 |
Re: Fixrupr
Really nice job on the paint, this isn't your first paint job is it?
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
10-21-2011, 06:53 AM | #108 |
landarts
Re: Fixrupr
Yes it is my first paint job. Lots of reading, research, asking questions. Then I started with small parts like all the items under the hood and the firewall. I chose to paint the truck in parts. Started with the inside of the cab , then shot the doors, front fenders and hood on the next go around.
I wanted to learn the process so I took the jump.
10-21-2011, 11:38 AM | #109 |
landarts
Re: Fixrupr
Headed back out to the shop to paint the bed now. Had to go to Napa and pickup a different temperature reducer for the base and clear. When I painted a few weeks ago I used the cr734 which has a range from 80 to 100. Temps have drop since then, today its supposed to be around 70-71. Went with the cr732 which has a temp range of 60 to 70, should put me right on the money.
The paint job has used all Napa Crossfire products.
So far the products have work well and the coverage was great.
10-21-2011, 11:45 AM | #110 |
67cheby
Re: Fixrupr
careful today with that big of a temp difference it changes the whole game !
10-22-2011, 10:35 AM | #111 |
landarts
Re: Fixrupr
Got the bed sealed and the first coat of base on. Found an area that needs to be fixed before I spray the other two coats of base and the clear.
Pictures to follow.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer Last edited by landarts; 10-22-2011 at 11:26 AM. |
10-22-2011, 11:27 AM | #112 |
landarts
Re: Fixrupr
Here are the pictures from the first coat of base.
10-22-2011, 11:35 AM | #113 |
landarts
Re: Fixrupr
Here is the area that needs to be fixed before going further....see picture
10-22-2011, 12:23 PM | #114 |
67cheby
Re: Fixrupr
nice work
10-22-2011, 12:25 PM | #115 |
landarts
Re: Fixrupr
Here a picture of adding 2k primer surfacer to the area that was low.
10-22-2011, 05:19 PM | #116 |
VA72C10
Re: Fixrupr
Looking good!
Looking for a 67-72 swb or blazer project in or around VA. |
10-22-2011, 08:04 PM | #117 |
landarts
Re: Fixrupr
Here is the repair made. Clean up and wipe down, get ready to finish the paint on the bed in the morning.
For this repair I taped some mask paper around the area to be repaired so the filler primmer would not get all over everything. Then turned down the fan pattern on the gun and feathered in the filler primer in the area that was low. I had two high power halogen lamps helping with the drying times. Laid down about 4 coats over the low area with about 10 to 15 minutes between coats. Went back in the house and watched the Boise State football game while thing cured up. Went out at Halftime and added two more dedicated breakers to my electrical panel so that I would have a dedicated for the compressor and a dedicated breaker for all the lights we are using while painting. Here is a few shots of the repair after wet sanding with 320 and feathering with 800.
10-23-2011, 12:08 PM | #118 |
Re: Fixrupr
Nice work on the repair spot, good thing you got it before you got too far along.
keep up the good work man!
John Mild Custom 68' Work Truck Build Facebook LoL 1977 Trans Am (Project) 1965 Chevelle (Project) |
10-23-2011, 12:41 PM | #119 |
Re: Fixrupr
That looks very nice. I too will be attempting my first paint job on mine...that will probably be in 10 yrs
10-23-2011, 06:49 PM | #120 |
landarts
Re: Fixrupr
Got the repair completed and shot the final two coats of base and 2 coats of clear today. Yahoo! The pictures came out funny, the circles you see are from the camera not the paint.
Start taping off the cab Monday and spray on Tuesday.
10-23-2011, 06:54 PM | #121 |
VA72C10
Re: Fixrupr
Looking good! Yeah, the camera sees the paint/dust in the air which is the circles...or some on the lens itself...
10-23-2011, 09:23 PM | #122 |
landarts
Re: Fixrupr
Its the lens I dropped the camera on the carpet and did not bother to clean it. I will have to be fore i shot any more picts.
10-23-2011, 10:05 PM | #123 |
67cheby
Re: Fixrupr
nice
10-25-2011, 09:14 AM | #124 |
landarts
Re: Fixrupr
Paint schedule for the next few days.
Tuesday - finish prepping small parts that need painting like the following:
And a few more odds and ends. Wednesday - Prep cab for painting , clean and mask Thursday or Friday paint cab!
10-26-2011, 06:15 PM | #125 |
landarts
Re: Fixrupr
Let me tell you about a cool happening. Last week I listed a complete 1967 front clip on the local craigslist for $400. I got a few calls right after I listed, but as usual a few no shows. Typical for most Craigslist shoppers. Monday I received a call from a guy that was interested in the clip, he kept talking about how he bought this 4x4 that had a wrecked front end and needed to replace it. Then he goes on to say that he was really looking for a 72 clip for the truck.
Well I happen to have one of those over at the storage unit next my house, I told him that that clip was 100% complete, rust free and the body work had already been done. He says give me your address and I will come and get Tuesday afternoon. I gave him the address and the next day he shows up with the $450 and we load it. Then he goes on to tell me that he drove 10 hours from Vegas to get it and was on his way back so he would'nt be late for work. Wow I was blown away that I had local people that said they were on there way over and never showed, this guy drove 10 hours one way. Now thats dedication to your cause.
