12-09-2012, 09:19 PM | #1 |
rear quarter panels for suburban
anyone know where to get a full quarter panel or patch panels for 55-59 suburban/panel ?
1969 chevy c10 lwb stepside 250 6 3 ott 1971 chevy c10 lwb 250 6 with power steering 3 ott 1972 chevy k20 4x4 350/TH350 automatic 1978 chevy Malibu 4dr 305 2bbl (all original) 1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver) |
12-10-2012, 06:33 PM | #2 |
Re: rear quarter panels for suburban
Sadly nothing is being repopped for these. The 59 burb I had was so eaten away around the rear wheels i could almost crawl through the holes. the 58-59 fleetside beds are close but not the same.
Posted via Mobile Device |
12-10-2012, 06:56 PM | #3 |
like meter swinger said, no patch panels unless it would fit on a short step side truck.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
12-10-2012, 07:02 PM | #4 |
12-10-2012, 09:06 PM | #5 |
Hollister Road Co.
post a picture of what you have to work with. There are other years and models that you can scavenge parts from to reproduce the panels.
12-11-2012, 03:27 PM | #6 |
the fender opening is suposed to be the same as the stepside fenders. I saved the openings off the fleetside I cut up for Big Bertha in case I ever come across a burb that needs quarters. Thaey are colse enough for me and probably no one would notice.
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
12-11-2012, 11:12 PM | #7 |
i own both. chose to rebuild the short step side because it was easy peasy
11-19-2016, 10:31 AM | #8 |
Also been after a set of repro quarters for my (rough)1959 panel up in the rust belt….have you folks ever found anything out there? I am tempted to buy a brand new set of stepside fenders to steal wheel arches out of as I am not enough of a body guy to form new ones from scratch. Is this similarity just a myth or has anyone ever tried it? I've also thought of finding quarters from a similar era car to patch in.
Thanks! |
11-19-2016, 03:54 PM | #9 |
Dealing with the same problem with my '56 panel-
60-66 fleetside bedsides should give you the sheetmetal, but the edge/wheel lip is thinner... 58-59 fleetside sides will work, but only give you enough metal up to the spear. |
11-19-2016, 07:19 PM | #10 |
guys go over to stovebolt.com. there is a suburban forum and One of the guys makes the 47-53 suburban rear corners. I think his handle is metalman and he can build anything yu need.
