04-29-2018, 11:25 AM | #1 |
Headlight / Wiper switch ground 72 GMC
Relocating the headlight and wiper switch on my truck to a wooden bezel(long story). Question is, do I need to worry about losing ground as the switch housings will not be contacting the sheet metal on the dash any longer.
Lights all have their own grounds, guessing the wiper motor does also. So in my mind I should be ok, just not positive I am right. Any help appreciated.
72 GMC Jimmy |
04-29-2018, 01:38 PM | #2 |
Msgt USAF Ret
Re: Headlight / Wiper switch ground 72 GMC
Sorry to disappoint you but the wiper speeds are switched by the switch on the grounded side. The positive power comes from the fuse panel and goes directly to the motor. All your lights and instruments will have to be grounded in the cluster as well. The fuel gauge, the temperature gauge, and the instrument lights are normally grounded to the cluster.
The brake warning and the turn indicators are not grounded to the cluster but the high beam light is.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
04-29-2018, 02:53 PM | #3 |
If you want the headlight switch to operate the dome light then it will need to be grounded too.
04-29-2018, 03:12 PM | #4 |
I've got the gauges and indicator lights grounded to the firewall, so good there. Not disappointed, shouldn't be a big deal to run a ground from these switches while I am putting it together. Would be a big deal if I got it all put together before I added the grounds.
According to the diagram I found on here, the courtesy lights are grounded through the plug - but I am guessing now that plug gets its ground right there at the dash then. Its a Jimmy so no dome or cargo light. http://67-72chevytrucks.com/vboard/s...d.php?t=509049 Thanks for the replies.
72 GMC Jimmy |
04-29-2018, 03:59 PM | #5 |
Correct, the male terminal on the switch to the courtesy circuit is through the plug but the switch either needs to be grounded via the dash mount or a separate female ground terminal needs to be connected to the male terminal on the outside of the switch. (The top terminal in the drawing with the ground symbol.) The plug doesn't connect to that terminal.
04-29-2018, 04:34 PM | #6 | |
Appreciate the help.
72 GMC Jimmy |
04-29-2018, 05:50 PM | #7 |
Maybe you can find room on the housing to install a self-tapping sheet metal screw to attach a ground wire.
