11-30-2010, 12:45 PM | #1 |
90 350 TBI wont idle down.
I have a junkyard fresh 350 in my 90 Silverado. When I put the "new" engine in I swapped my TBI unit the sensors, harness and everything else to the junkyard engine. When I bought the truck it wouldnt idle down when stopping and putting the truck in neutral or between gear changes. The new engine acts the same, so I'm guessing I have a bad sensor. I have had the Check Engine Light come and found a faulty temp sensor, I replaced that and a month later, while a friend was running diagnostics found the temp sensor had failed again, it was reading too hot. I have replaced the temp sensor again, and the truck still idles too high or wont idle down. Other than the temp sensor we found no other codes.
When I swapped the new engine I left the smog pump off and the truck had the catalytic converters removed. Recently sitting at a fast food drive through the truck idled down but I could smell the truck running rich. Any help puzzling this out is greatly appreciated.
88 Chevy C1500, step side, LS swap. 98 Crew Cab Dually, tow rig. 03 Dodge Neon. ECTA Ohio Mile record holder. |
11-30-2010, 04:14 PM | #2 |
Re: 90 350 TBI wont idle down.
More specific information is needed.
Which coolant sensor code or codes were stored? What number? Does it still set the trouble code when it is driven? Did you change the ECM? Is the ECM in the truck the original? Did the truck have a 350 in it before the swap? Have you checked for vacuum leaks? Have you tried pinching off the vacuum hose to the brake booster?
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
11-30-2010, 04:16 PM | #3 |
Have you tried blocking the IAC port?
11-30-2010, 04:29 PM | #4 |
I dont remember the code, I think I have it written down I will look for it. The first engine was a 350, I did not change the ECM. I used the junkyard engine's intake manifold, and it looked like it had never been off. I have checked for vac leaks and found none.
After swapping engines I did install an open element air cleaner, however the truck ran the same with or without an enclosed aircleaner. The truck is a factory 350 V-8, with a 5 speed manual transmission. I havent messed with the IAC.
88 Chevy C1500, step side, LS swap. 98 Crew Cab Dually, tow rig. 03 Dodge Neon. ECTA Ohio Mile record holder. Last edited by MotorHead Lon; 11-30-2010 at 04:31 PM. |
11-30-2010, 04:59 PM | #5 |
Check to see what codes are in it now.
Here are some web sites with the basics on retrieving codes, on OBD1 systems, without a scan tool or code reader. Poor drawing of ALDL but ok instruction + codes http://www.cfm-tech.com/gm_tbi_trouble_codes.htm OBDI terminal identification http://robertpowersmotorsports.frees.../ALDL_plug.jpg OBDI illustration and instructions http://www.troublecodes.net/GM/ Good explanation http://www.syty.org/old/d&e.html
11-30-2010, 05:11 PM | #6 |
I got a 13 code. I left the paper clip in for a minute to see if anything else pops up and it just repeated the 13 code, no signal to computer from oxygen sensor.
88 Chevy C1500, step side, LS swap. 98 Crew Cab Dually, tow rig. 03 Dodge Neon. ECTA Ohio Mile record holder. Last edited by MotorHead Lon; 11-30-2010 at 05:13 PM. |
03-26-2011, 08:41 PM | #7 |
I have had that issue before and it was the fact I had the rong TPS in it.
87 Chevy R10 LB 02 Nissan Sentra GXE |
