Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 09-06-2017, 09:59 AM   #1
jeremywrags
What to do about this rust?
Hi All,
I am starting to look at some of the rust on my cab, it's not to bad in my mind but then I am pretty new to this...
used a wire brush on my drill to clean it up a bit but how would one deal with this? It's not rotted through but it's rough to the touch
jeremywrags is offline   Reply With Quote
Old 09-06-2017, 12:18 PM   #2
bs46488
Re: What to do about this rust?
What part of the US are you in?
What is your goal with the truck?
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 09-06-2017, 12:22 PM   #3
jeremywrags
Northeast OK, near Tulsa. The plan with the truck is to do a frame off "restoration". I want to keep a semi old school look, all the emblems\trim\chrome but lower it a little and put some nice wheels\tires on it. For the inside, I want it to look original ish...
Old 09-06-2017, 06:36 PM   #4
72HuggerK20
Sandblast it, epoxy prime, skim coat it, sand it down smooth, and then prime/seal/paint like normal.
72HuggerK20 is offline   Reply With Quote
Old 09-06-2017, 09:04 PM   #5
franken
Wire brushing sort of polishes the rust and makes it look like its gone. Sand it and you'll most likely find its still there.
franken is offline   Reply With Quote
Old 09-19-2017, 09:22 AM   #6
In The Ten Ring
Sandblasting sheet metal can cause warping, I have been told "crushed glass" is the way to go.
In The Ten Ring is offline   Reply With Quote
Old 09-19-2017, 06:00 PM   #7
Foot Stomper
Foot Stomper's Avatar
Get some epoxy primer on those bare spots or they too will start to rust.
Bare metal needs epoxy primer. Not self etching primer or DTM (Direct to Metal) type products...only epoxy. Doesn't matter which one, they are all the same for corrosion prevention.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
