Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 02-08-2017, 01:10 PM   #1
red02chevy
Arrow Portertbuilt items
After going through all my parts I have several Porterbuilt components that I will not be using on my build. All items are new or have been bolted to my chassis but have zero miles. Everything is located in Lubbock, TX. Shipping can be arranged on everything.
  • Carrier bearing cross member. This bolts to the chassis just before the rear cab mount and is tubular so you can run exhaust through it. $200
  • Tubular carrier bearing cross member $75
  • Upper dropmember hats with shocks and shock mounts. Made for the extreme dropmemeber and air bags. KYB shocks included. $275
  • Poterbuilt Rear upper bridge with lower bag brackets. Bridge includes upper bag and shock mounts. $350
red02chevy is offline   Reply With Quote
Old 02-08-2017, 02:08 PM   #2
mrblalock66
Re: Portertbuilt items
Interested PM Sent
mrblalock66 is offline   Reply With Quote
Old 02-09-2017, 11:02 AM   #3
HunterRotten
HunterRotten's Avatar
I'm interested in the crossmember but I have a few questions about it. I currently have the crossmember that allows the driverside exhaust to run under it and the passenger side to run ontop of it but it currently needs modifcation so that the transmission will sit better on a transmission mount.
Will the porterbuilt transmission crossmember interfere with the exhaust pipes I already have and mess up the pinion angle I have set currently? If you can't answer I can get ahold of porterbuilt and ask them I suppose.
Thanks!
HunterRotten is offline   Reply With Quote
Old 02-09-2017, 09:25 PM   #4
MONTEZ
Will the carrier bearing crossmember fit an 84? Would you ship to Nacogdoches?
Smoke Tires, not Drugs
MONTEZ is offline   Reply With Quote
Old 02-18-2017, 12:42 AM   #5
jbristo67
resident oilfield trash
jbristo67's Avatar
Hey do you still have your stock leafs for your truck
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 03-18-2017, 12:30 PM   #6
MONTEZ
You still around? I sent PayPal for the tubular bearing carrier mount.
Old 09-27-2017, 11:59 PM   #7
gvillersx
what all do you have left and will it fit a 72
gvillersx is offline   Reply With Quote
