Old 01-16-2017, 11:55 AM   #1
Todd68Chevy
Todd68Chevy's Avatar
Longhorn Automatic transmission cross member removal
I figure this has been asked before but I searched and couldn't find the answer. I have removed several 1/2 and 3/4 ton cross members by beating them sideways and I am wondering if there is room to do that with a Longhorn that has the frame spacers attached or do I have to remove rivets and take it apart to get it out of the frame? Thanks
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
Old 01-16-2017, 01:16 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Longhorn Automatic transmission cross member removal
If you remove the frame spacers on the bottom, you should be able to tap the cross member out with your hammer. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-16-2017, 01:55 PM   #3
Todd68Chevy
Thanks, I was trying to avoid cutting the rivets between the brackets and the cross member. Is there any good way to cut them? Does not look like a grinder will fit. I usually use an air chisel on rivets but looks pretty hard to get into them.
Old 01-17-2017, 07:40 PM   #4
crazy longhorn
Scrape all the mud/crud, & fire up the torch Longhorn
Old 01-18-2017, 08:56 AM   #5
Todd68Chevy
I have cleaned it up since this picture but this was the only picture I had of it. I know I can get it out if I cut the frame but don't want to destroy the frame incase someone needs it. Thanks for the help
Old 01-18-2017, 05:57 PM   #6
crazy longhorn
No, I did not suggest to cut the frame, just burn the rivets. If you are just making parts out of the truck, another thought....reach in & burn the outboard pcs off the bottom spacer? The cross member can still be sold to use in a 1/2 or 3/4 ton truck (non longhorn), or the bottom spacers should not be that bad to make (fab), for longhorn useage. Longhorn
Old 02-02-2017, 08:49 AM   #7
Todd68Chevy
So everyone knows the cross member will twist sideways and come out like the standard 1/2 ton style. I might have bent the bottom bracket some but I can not tell. I moved the passenger side back as far as I could with the exhaust hanger in the way. Placed a pair of vice grips in front of it so it would not slide forward. beat the drivers side forward and after getting the parking brake cable out of the way it moved far enough to come out of the frame rails. I am not sure it would go back in that way but now that it is out of the truck I can get to the spacer bracket rivets to remove them and then bolt it back together.
Thanks Crazy Longhorn for the help/ advise.
Old 02-04-2017, 12:39 AM   #8
crazy longhorn
Not a problem.....crap, you showed me something, that I did not think would go! Damn sure, that it wont go back in like that (but you had it figured). My old truck has a couple custom built cross members (tucked + trimmed). the exhaust goes under, but up tight.....longhorn
