08-17-2020, 04:31 PM | #1 |
64 Chevy C10 Spindle Confirmation
Good Afternoon!
Forgive me. When I uploaded my spindle picture, the upload process turned the picture 180 degrees. So it is totally upside down. I could not figure out how to turn it back round once I uploaded to the site. Please tell me how to correct this for the future. I am hoping that when you read this, the picture can be rotated. Since my wheel bearing have gotten noisy, and since I have no idea how long the current rotors and calipers have been on, I wanted to change out the entire setup. I am hoping I can use the existing spindles. Can you tell from the picture if the spindle looks like an OEM drum spindle? I think it is. My desire is to use the existing spindles. I took that approach for my Chevy car and it worked out fine. If I go this route, I just want to make sure and not order a kit that will not be compatible with the spindles I have. I will be thankful for all responses. Edward |
08-17-2020, 09:42 PM | #2 |
60-66 Nut
Re: 64 Chevy C10 Spindle Confirmation
No that is definitely not an original drum brake spindle. It looks to me like a '73-'87 spindle. It is quite easy and in expensive to just change the bearings and seals.
08-17-2020, 11:15 PM | #3 |
I hear you Captain. Thank you.
Edward |
08-18-2020, 09:51 AM | #4 |
Saved & flipped.….
