01-27-2018, 06:05 PM | #1 |
72 BB C30 Super LongHorn
1972 c/30 bb longhorn
Here is the start of my Longhorn rebuid/restore.
This is a complete bumper to bumper original unmolested truck. Its time to do her!
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS |
01-27-2018, 06:09 PM | #2 |
Re: 1972 c/30 bb longhorn
Started with taking off the original Quadrajet for rebuilding :
7042206 QA Pulled the original points distributor out: 1112064
01-27-2018, 06:12 PM | #3 |
Will now begin on the brake system :
Rotor original ID code : GX
01-27-2018, 10:37 PM | #4 |
Pulled the original calipers off and put on a set of rebuilt ones for the time being until I can get them SS sleeved; along with the original M/C.
Got the system pressurized up front. Now onto the rears.
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 01-28-2018 at 01:58 PM. |
01-27-2018, 10:41 PM | #5 |
Rear axle
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 01-27-2018 at 11:22 PM. |
01-27-2018, 11:23 PM | #6 |
Another undercarriage image....
01-27-2018, 11:35 PM | #7 |
Big Brakes
01-28-2018, 01:25 AM | #8 |
Oh wow. Super cool. Subscribed! Any other pictures of the truck or the SPID? What are the plans?
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Project "Little Sister" (70 c10 blue original paint refresh) Project "C10 Fever" (68 factory black 396 swb) Project "Blue Bomb" (70 c30 blue original paint refresh) Project "Vitamin C" (71 c10 orange original paint refresh) |
01-28-2018, 01:48 AM | #9 |
67-72 parts collector,…
Subscribing,
01-28-2018, 02:04 PM | #10 | |
will look again. Plans: I will remove the original 402 engine and T-400 and install a 496 i just had done. Rebuild an extra T-400 I have and add a GearVendor to it. I'm going to pull the HO72 in it and rebuild that at a later date. I have a 14-Bolt 3:42 Posi rear to install into it. Just waiting on the leaf & shock mounts to be relocated on it. Otherwise I am going go thru everything on it.
01-28-2018, 10:52 PM | #11 |
Got into the left rear brake.
Wheel cylinder was locked up. Disassembled & did a simple clean up. Last image simple rebuild... Here is the drum :
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 02-03-2018 at 06:00 PM. |
01-31-2018, 10:04 PM | #12 |
6>8 Plugless........
Very nice Longhorn! I have one in my garage right now that is probably close to the same as yours. It is a pretty optioned up C30 Super too. Here's a pic of the spid.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-01-2018, 02:55 AM | #13 |
Nice!
Wish mine was a bucket seat truck. This will be a slow rebuild But each weekend we will get after it
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 02-01-2018 at 10:28 AM. |
02-01-2018, 10:29 AM | #14 |
Anyone have any idea how many Longhorn trucks were assembled as C 30 builds?
02-01-2018, 07:40 PM | #15 |
02-04-2018, 12:01 AM | #16 | |
Thanx But like everything; a breakdown of vehicles optioned would be ideal and difficult to provide. Nice resource
02-04-2018, 12:05 AM | #17 |
I got into the right rear brake.
I'm going to need to find a replacement drum as it was scored badly beyond usable. The wheel cylinder on this side was leaking. Need to locate a replacement spring for the top bar below the wheel cylinder. It broke as I removed it. That's it for today
02-04-2018, 01:42 AM | #18 |
I have 1 ho52 that is for parts. I could pull it apart and check it out for ya.
02-04-2018, 03:24 PM | #19 |
OK, COOL... THANX
02-04-2018, 05:14 PM | #20 |
Id like to locate some original pins with the raised 1 that are mint, undamaged, & straight.
Here is also a pic of the springs I need...
02-06-2018, 12:07 AM | #21 |
I'll work on getting it dug out and getting the hub off as soon as I can.
02-06-2018, 02:26 AM | #22 |
All good here
No rush I found a 12" drum but I'm still digging for a 13" one. All this takes time
02-10-2018, 08:13 PM | #23 |
OK...
So I'm looking for a replacement 1972 issue GM 13" rear brake drum. Part # 48716 is present in the 1972 drum; actually shows ---> 48716 4. Here, in the pic below , is a comparison between the 1972 drum on the right and the 14-Bolt 13" drum on the left. Both use the same shoe width. The 14-Bolt drum is thicker where the hub is installed; maybe by approx 1/8". The backing plates are identical except for where the pin goes thru. We are going to try to install the 14-Bolt drum with the 1972 hub installed and see if it can be used. The original 1972 backing plate is currently installed for this trial install.
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 02-10-2018 at 08:19 PM. |
02-10-2018, 09:02 PM | #24 |
14-Bolt drum installed with shoes in place...
It fits without hitting anything Factory studs are too short with the thicker drum
02-11-2018, 01:23 PM | #25 |
While I am awaiting for some of the new replacement brake parts to arrive,
I decided next to remove the driveshaft assembly. I don't recall ever seeing these before on prior trucks, but at the carrier bearing, the securing bolts have a bolt with a drilled hole into then using a slide pin as shown :
