Old 08-23-2017, 10:10 AM   #1
'70_402
'70_402's Avatar
Full length braided hose?
Can I run full length braided fuel line from my rear tank to the ls motor? I've read that some people like to use hard line, some use all braid. I have no experience with any of this....
'70_402 is offline   Reply With Quote
Old 08-23-2017, 10:11 AM   #2
jocko
jocko's Avatar
Re: Full length braided hose?
You can, but I'd run a hard line anyway. Uncle GM knew what he was doing.
Old 08-23-2017, 10:40 AM   #3
MikeB
MikeB's Avatar
A problem with braided hose is it's still rubber inside, and rubber will eventually deteriorate, even though the braid still looks like new. Also, hose is susceptible to being damaged by road debris.
If you do use hose, run it as high off the ground as possible and inside the frame rails. And keep it away from exhaust pipes and mufflers.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 08-23-2017, 10:46 AM   #4
67 chevelle
67 chevelle's Avatar
run hard line from the regulator , quick connect with 3/8 compression fitting up front so you only need 18 inches or so of braid -6 ,COST , braid is expensive
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 08-23-2017, 11:25 AM   #5
'70_402
'70_402's Avatar
I'm getting a boyds tank, so i think i'm just gonna go ahead and get the FI install kit from Pro Performance.
Old 08-23-2017, 11:55 AM   #6
boraxman
Keepin an eye out
boraxman's Avatar
I was thinking about getting that kit for mine...I would like to see someone post up an actual parts list (with #s) to see if I can source what I need for cheaper...I already have some stuff...
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 08-23-2017, 01:57 PM   #7
skinnan
what is a good source for hard line?
skinnan is offline   Reply With Quote
Old 08-23-2017, 03:08 PM   #8
CountofMonteCarlo84
If you run a braided line, make sure it has an inner teflon line inside and not rubber. Ask me how I know... like MikeB said above.
CountofMonteCarlo84 is offline   Reply With Quote
Old 08-23-2017, 04:50 PM   #9
rx78nt1alex
rx78nt1alex's Avatar
You can go to any auto parts store and buy a coil of tubing, 3/8ths is good. I think they sell it in 20-25 foot lengths. Or if you know someone in industrial instrumentation, you can get a hold of 3/8ths stainless steel tubing.
The auto parts tubing is soft and is good for the flaring tool. SS is harder, but with a bit of effort, you can flare it. Or just use swagelok tubing unions and ferrules.
1968 Chevrolet Fleetside C-10
1971 Chevrolet Fleetside C-10
rx78nt1alex is offline   Reply With Quote
Old 08-23-2017, 05:30 PM   #10
skinnan
Apparently you can get 25' rolls of tubing on Amazon or there is a really great site for this kind of stuff called Inline Tube http://www.inlinetube.com
Old 08-23-2017, 09:15 PM   #11
'70_402
'70_402's Avatar
I asked what brand fittings and hose they used and it's XRP stuff.. i priced a few things, and realized it's worth it to get the kit... you might be able to save a few bucks, but Pro Performance gave me a good deal on the package with the EFI tank.
Old 10-04-2017, 09:40 PM   #12
HotRodfuelhose
Active Member
The PTFE stuff we sell will not break down and is very chemical resistant. I ran it from my tank to FItech. www.hotrodfuelhose.com
HotRodfuelhose is offline   Reply With Quote
Old 10-04-2017, 11:30 PM   #13
crakarjax
crakarjax's Avatar
Don't be afraid to buy cheap hose if it's fully specified, it's a commodity item... this Proclassic II look alike fits the bill for $62 with numerous fittings included https://goo.gl/ZEDJRb
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 10-05-2017, 01:23 PM   #14
MikeB
MikeB's Avatar
Good to know.
Mike
Old 10-05-2017, 01:31 PM   #15
davepl
davepl's Avatar
I've just converted two vehicles from -10AN (or -8AN) to hard line. In both cases it was for odor in the garage. Both had steel braided rubber line that was about 10 years old.
Unless you use the new materials out there that are supposed to be ethanol safe, or use teflon (PTFE), it will smell in the garage eventually as the modern gasolines seep through the rubber
Unfortunately one of them was on a high-performance truck with two tanks and two pumps and the crazy tank switch w/ return provision was $700! But I digress...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-05-2017, 01:37 PM   #16
CountofMonteCarlo84
This is accurate. I had the same issue and went with Teflon.
Old 10-05-2017, 02:11 PM   #17
truckdude239
truckdude239's Avatar
i used th ptfe braided hose and its been 3 years so far no problems
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 10-05-2017, 03:15 PM   #18
Killer Bee
Killer Bee's Avatar
steel braid cons;
  • abrasive to surroundings, very abrasive
  • vulnerable to various forms of deterioration
  • vulnerable to squeeze, crush, kinks, etc.
  • above conditions even to slight degree can create turbulent flow
  • bulging/collapsing, pressure variances
  • 'flappers' can give you a fit troubleshooting
  • bulkier cross section per ID tube size
  • difficult to run clean sight lines over long distances
  • very little heat rejection
  • expensive
steel braid pros;
  • easy installation
rigid line cons;
  • more difficult to install
rigid line pros;
  • negligible deterioration factor
  • less vulnerable to physical damage
  • better laminar flow
  • stable pressure
  • good heat rejection
  • thinner cross section per ID tube size
  • flame and spark resistant
  • clean installation sight lines
not comparing external corrosion factors as that entirely depends on the material specified, operating environment, and maintenance.. there are various CRES options for both.. I ran .500 AL in my 550hp gto, it was beautiful
steel braid hoses [genuine, not fake tubing socks] is heartier than soft hose alone, like an armor plating but still shouldn't be routed anywhere you normally wouldn't route typical soft hose..
I've seen steel braid compressor discharge hose [teflon lined] eat COMPLETELY though rocker covers on N14s and 60srs.. I mean down to an actual oil leak.. be weary of tossing a spool of steel braid down the frame rail without regard to everything it comes into contact with.. there, said my piece on that..
as mentioned above, manufacturing engineers have determined the which is best for typical automotive application.. most run rigid everywhere possible and only use soft hose for connections between moving parts..
good luck on your project!
Old 10-05-2017, 03:33 PM   #19
crakarjax
crakarjax's Avatar
By 'best' you mean lowest cost with an acceptable mean time between failures right?
Old 10-05-2017, 03:51 PM   #20
Killer Bee
Killer Bee's Avatar
the manufactured failure philosophy may apply to glove box doors, but not so much on critical systems, modern times anyways..
auto, truck, and equipment manufacturers are not interested in getting sued out of existence..
so by best I mean with regards to safety, performance, design life, warranty and other liabilities..
run or recommend what you choose, but I've had my hands on enough fuel lines to reach the moon and one thing is explicitly common between just about every one of them..
good luck y'all!
Old 10-05-2017, 06:27 PM   #21
indymachinist
Summit sells aluminum tube in various diameters and lengths suitable to run from the back to the front. Perfectly good way to go.
I do not support soft line all the way from the tank to the engine, even if it is proper fuel safe line. (Which most of it isn't)
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 10-05-2017, 07:00 PM   #22
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I just bent my own 3/8" hard line out of NiCop and mounted it along the frame rail. Bends easily with a good tubing bender and is easy to "tweak" if you need a slight bend to make fittings thread in easily.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 10-05-2017, 09:12 PM   #23
In The Ten Ring
You don't need braided hose! That's just a sales gimmick. Run rubber hose from tank to carb......done.
And you also get to enjoy the engine fire that burns your truck to the ground.
Run as much hard line as you can, you may use braided hose between joints if you must but keep those lengths short. That is what I was told on here back when I went through this issue a couple of years ago.
In The Ten Ring is offline   Reply With Quote
Old 10-05-2017, 09:32 PM   #24
mike16
rubber hose is good for 2 years.
steel braided hose does not last longer but the steel braided outer surface protects from abrasion that might cause hose failure.
some are guarrenteed for life... but dont bet your life on that.
mount hose below any electrical items
most racing organisations limit the number of and length of flexible hazardous fluid lines permited to be used on vehicles
mike16 is offline   Reply With Quote
