Old 08-17-2018, 10:26 PM   #1
diveplane
clutch noise
anyone know how i can eliminate slave cylinder piston creak
i tried blasting some oil in drain hole bottom of bell housing where slave unit is mounted, the noise is coming from here , as i had someone engage the clutch
while i was underneath.
do i need to remove the slave unit to lube piston? no need to remove hydraulic line? never did this before..
diveplane is offline   Reply With Quote
Old 08-18-2018, 08:40 AM   #2
Re: clutch noise
I have never had on that made noises. Your idea makes sense, but to me it sounds like a replacement of the slave cylinder is due.
Note/Afterthought....I wonder if your throw-out bearing on the clutch is the part of the issue.
Old 08-18-2018, 11:33 AM   #3
diveplane
Re: clutch noise
no its when i apply the clutch noise, the clutch was redone year ago new plates and bearing.
Old 08-18-2018, 11:48 AM   #4
diveplane
Re: clutch noise
replacing the slave unit easy job then?
Old 08-18-2018, 01:28 PM   #5
Re: clutch noise
I had one vehicle that it was accessible for the outside of the bell housing and one I had to remove the tranny to access it inside the bell housing. (V6 C1500 and S10 4 banger) I don't remember which one was which. The outside one was very easy.
Old 08-19-2018, 02:36 PM   #6
diveplane
Re: clutch noise
wow the noise is away i managed to clean the slave unit and some oil on it,
also cleaned up my transmission with gunk gel amazing product,
clutch pedal feels smooth now.
if the noise ever returns i will replace the slave unit .
Old 08-19-2018, 05:25 PM   #7
Re: clutch noise
Good. Glad it works, hopefully for a LONG time.
