Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 07-28-2018, 09:17 AM   #1
panhead59
Question Led flashers
On a 68 do both flashers need to be led type for turn signals to work with leds ?
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom)
1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK.
1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive !
panhead59 is offline   Reply With Quote
Old 07-28-2018, 04:42 PM   #2
dmjlambert
dmjlambert's Avatar
Re: Led flashers
There is one flasher for the turn signals to work, and another flasher for the hazard lights.
dmjlambert is offline   Reply With Quote
Old 07-28-2018, 05:22 PM   #3
panhead59
Re: Led flashers
Yeah i know the other flasher is for hazards. Same ? - do BOTH need to be for leds for either to work ? I'm guessing yes.
Old 07-28-2018, 05:46 PM   #4
dmjlambert
dmjlambert's Avatar
Re: Led flashers
If you are using LED light bulbs, you can replace both hazard and turn signal flashers with flashers that are compatible with LED bulbs, in order for both your turn signals to work and for your hazard lights to work. Or, install load resistors into the wiring so you can use standard flashers with your LED bulbs.
Old 07-28-2018, 06:02 PM   #5
dmjlambert
dmjlambert's Avatar
Re: Led flashers
Sorry, I just re-read your question and I'm not sure what you mean "for either to work." But I think you mean will the turn signal work properly by only replacing the turn signal flasher, and I believe the answer is yes. So if you are only concerned about turn signals, and not worried about the hazard lights working, then just replace the one flasher. I think it is common for most people to replace both flashers at one time, with the same part number flasher. The one that I have seen people endorse here on the board is the 2-prong electronic type with a ground lead pigtail.
Here is one: https://www.amazon.com/dp/B01GIU9M0Y
Old 07-29-2018, 06:05 AM   #6
panhead59
Re: Led flashers
Ok now we are on the same page. I had only bought one flasher, like a dummy. Turn signals light but don't flash. Reversed polarity on one flasher and drivers side gets bright when turned on but still doesn't flash. I'll get a second flasher today and go from there.
Old 08-07-2018, 03:59 PM   #7
Robznob11
Robznob11's Avatar
Re: Led flashers
Hmmmm that sounds weird...it should work on turn with only the turn flasher in...I would have thought by reversing the polarity that would solve the issue...I would think in this case either the flasher you chose is giving you issues or there is some other issue. I'm guessing you have leds in front and back? Almost sounds like a poor ground.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 08-07-2018, 05:45 PM   #8
panhead59
Re: Led flashers
I now have both flashers made for leds installed. Problem solved, both led turn and hazards work as they should. Found one "bulb holder" in dash that wasn't making good connection. Right turn signal indicator. Sanded prongs that hold bulb and it works although intermittingly. I don't see those bulb holders in parts catalog. Where can i buy a couple ? Tks for all the help. Leds look cool/bright.
Old 08-07-2018, 07:18 PM   #9
dmjlambert
dmjlambert's Avatar
Re: Led flashers
I got one at Advance Auto Parts. It was about $8, I remember not liking that price very much. I think they are widely available online too. Here's one at the bottom of this page
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=89
Old 08-07-2018, 07:20 PM   #10
dmjlambert
dmjlambert's Avatar
Re: Led flashers
If you have a gauge cluster, then your Temp light is probably unused, and you probably have a bulb holder in that position. That is your spare bulb holder.
Old 08-09-2018, 09:51 AM   #11
panhead59
Re: Led flashers
I've got idiot lights, no gauges. Are the bulb holders available anywhere?
Old 08-09-2018, 08:40 PM   #12
dmjlambert
dmjlambert's Avatar
Re: Led flashers
Well since I got one for a high price at Advance Auto Parts then I think they may be available at other car parts stores also. If you don't find it locally, order some on eBay, Amazon, LMC Truck, etc.
Old 08-20-2018, 04:01 PM   #13
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Led flashers
Junkyards are full of them! For cheap.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
