Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-04-2018, 03:33 PM   #1
chip46wis
1972 c10 NSS
OK I am adding a 21 circuit wiring harness to my 72 using some factory connectors. Automatic trans. i see the 2 large factory purple wires from the NSS--- my question does the start purple wire from the ign switch go to one side of the NSS then continue to the starter? sounds right...
chip46wis is offline   Reply With Quote
Old 08-04-2018, 05:54 PM   #2
ray_mcavoy
Re: 1972 c10 NSS
Yes, one purple wire runs from the "SOL" terminal on the ignition switch to one side of the NSS. And another purple wire runs from the other side of the NSS to the "S" terminal on the starter solenoid.
The NSS contacts should be closed when the shifter is in Park or Neutral, allowing current to flow from the ignition switch to the starter solenoid. And the NSS contacts should be open in all other shifter positions, preventing the engine from cranking with the trans in gear.
ray_mcavoy is offline   Reply With Quote
