10-10-2010, 12:45 PM | #1 |
Roadtrip!
Stainless trim options ???
I ran across a bigger truck the other day with stainless trim around the side windows, and above and below the rear window, and in the windshield gasket. I think the truck is a 57 or 58. It is probably a 2 ton series. My question is, is this the same as the 1/2 and 3/4 tons? I assume it is worth pulling. It also has chrome escutcheons around the wiper stubs. Are those uncommon? I can post pics if that will help. Thanks for any info. Eric
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
10-10-2010, 01:43 PM | #2 |
Re: Stainless trim options ???
I know they offered stainless trim on the 58-59's, not sure on the previous years. You can get repop stuff from ecklers and such so you could check their online catalog and see if they fit the larger trucks.
10-10-2010, 02:08 PM | #3 |
It's the same. Get it if it's staight. The repop is VERY thin and flimsy.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
10-11-2010, 08:56 PM | #4 |
Roadtrip!
Update: i got a few pieces from it. Can anyone confirm what year it is? Anything else i should go back for? Thanks, Eric
10-12-2010, 08:05 AM | #5 |
Thats a LCF (low cab forward) truck. I would bring the hole thing home. would have to see the front clip to tell what year.
10-17-2010, 10:01 AM | #6 |
Roadtrip!
Blackdiesel, unfortunatley, all that is there is what is pictured. The clip is gone...
So are the parts i pulled the same as i pickup? Any ideas on values for the parts i grabbed? Thanks.
10-17-2010, 10:33 AM | #7 |
doors, steering wheel, dash if its not rusted out or hacked up, but you will need to cut it out. Those old lights sitting on top are cool too. Anything that is chrome or cool.
10-20-2010, 06:38 PM | #8 |
Roadtrip!
Any value ideas for the parts i pulled? I haven't been back for anything else yet. (if it is still there). Thanks.
10-21-2010, 01:57 AM | #9 |
CLASSIX Truck Club
From the steering wheel, It could be a 57-59. Around here, Ive seen the chrome trim go for a couple hundred bucks. The dash gauges is probably worth $75 (cleaned up) and not sure on the other. I had a 55 and a 59 so that's just my opinion on those parts when I was buying and selling.
10-21-2010, 06:04 PM | #10 |
Roadtrip!
Thanks Kalirodding, that helps. Eric
10-22-2010, 07:39 AM | #11 |
depends on condition. No dints and polished up, could be worth up to 3-4 hundred to the right person. Dents and bends drop the value fast. Look on ebay you can get a good idea of values. Yes they will fit a pick up al so.
10-22-2010, 09:23 PM | #12 |
Roadtrip!
Thanks for the info. The trim will clean up decent, but not perfect. Eric
