01-11-2016, 04:23 PM | #1 |
Drivers side window replacement help...
1969 C10 Drivers side window replacement.
I have searched high and low for a tutorial or directions and have found none. I have everything apart and don't know how to proceed with putting the new window in the bracket that attaches to the bottom of the glass (there is broken glass still in there. My window got shot out with a BB gun so right now there is glass in the channel where the new glass needs to sit. Any ideas on how to get it out? Also do I need some kind of adhesive/seal to keep the new glass in there? Hope that made sense.
The stupidty of your actions is directly proportionate to the number of people watching you... |
01-11-2016, 04:34 PM | #2 |
Re: Drivers side window replacement help...
I would just chisel it out with a small screwdriver. To reinstall new glass I think you just need a rubber window run channel to sandwich the glass and slide it back into the frame.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
01-11-2016, 04:41 PM | #3 | |
01-11-2016, 04:53 PM | #4 |
The proper way to do it is remove the old glass without damaging the channel, then get some "glass setting tape" available from amazon, ebay, or most any automotive glass company. and install the new glass in the channel with that. I have also used urethane windshield sealer, just make sure it is completely cured before putting the window back in.
"Negative people always seem to have a problem for every solution" |
01-12-2016, 12:06 AM | #5 |
tcoop68
LCM sells the glass complete with the metal tract already attached .
01-12-2016, 01:33 AM | #6 |
If reusing the original track be sure to get every spec of the old glass out. If you decide to bed the glass with urethane cut a few 1 " pieces of the old rubber and set them at each end of the glass and maybe one in the middle. It will hold the track and glass straight while the goop cures.
01-12-2016, 11:56 AM | #7 | |||
01-12-2016, 05:27 PM | #8 |
My glass shop does them for me, although the last time I went there, he said that they weren't going to make the right width/thickness setting tape anymore.
01-12-2016, 06:57 PM | #9 |
The window place I went to set the glass.....Now I have to reinstall everything. I had no idea its such a pain in the butt to get that vent window in.
Having trouble with it. Do I have to take the felt strips off that are on the door (think they are called window seals. The two small ones that go across the top part of the main door? Kinda by the door lock knob
01-12-2016, 08:22 PM | #10 | |
