08-12-2015, 02:21 AM | #1 |
70+ ( Old Skool Club )
Paint Code
Does anyone have a rattle can paint number or color, Krylon, Duplicolor, Tremclad or any other vendor that is the proper color for an original rim like the 1969 one in attached pic.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-13-2015, 04:43 PM | #2 |
Re: Paint Code
Bump
08-14-2015, 12:47 AM | #3 |
Re: Paint Code
This thread may help:
http://67-72chevytrucks.com/vboard/s...d.php?t=620516 However, even though I'm not using the original 8 lug wheels on my 69, I restored them using Rust-Oleum gloss white High Performance Enamel. Probably a bit too white, but I doubt anyone would notice. Jim |
08-14-2015, 04:02 PM | #4 |
Re: Paint Code
Thanks for the link FO69, I think the gloss white you used will be great and work for me if I can't find the GM paint.
08-15-2015, 12:41 AM | #5 |
Re: Paint Code
Tip..if you want to paint your rims with the tires on, use a deck of playing cards around the rim...
08-15-2015, 01:44 AM | #6 |
Re: Paint Code
That's a great tip...
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
08-15-2015, 11:47 AM | #7 |
US Army Veteran
Re: Paint Code
Rustoleum has a white called "Dove White" in rattle can that is sort of a light cream white. That's the first thing that came to mind when I saw the picture in the OP.
1972 C10 Highlander - The making of a daily driver |
08-15-2015, 01:29 PM | #8 |
Re: Paint Code
I'll check out the Dove White thanks an the rims will be painted with no tires on but thanks for the card tip anyway.
