Old 03-02-2018, 11:38 PM   #1
Pontiacgurudan
Dolphin Gauge Insert
Just got my dash insert today. I went with the Dolphin tan gauges with the stainless bezel. I'm going to sandblast the insert and hit it with satin black engine paint. I like the engine paint because once you bake it in under the heat lamps it's really durable. Since I have the 4l60e I needed to do something about the speedo and this seemed fairly easy. I plan to wire everything up and get it put together this weekend. More photos to follow.
Pontiacgurudan is offline   Reply With Quote
Old 03-03-2018, 02:06 PM   #2
61K10
61K10's Avatar
Re: Dolphin Gauge Insert
get it painted and post up some pics
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-04-2018, 02:47 PM   #3
Pontiacgurudan
I blasted the panel and painted it semi gloss black. I opted not to paint the bezel for now, I'll paint it white when I actually paint the truck. I removed the stock gauges from the bezel and the billet insert from dolphin went right into place. I have the gauges mounted into the inset and I'm ready to start wiring. I'm going to Monster Jam with the youngest today so I'll finish up tomorrow and get it programmed. It looks awesome so far.
Old 03-04-2018, 08:00 PM   #4
Macdaddy1
That looks great let me know how easy it is to wire as that is what I have planned for my gauges as well.
Pat
Macdaddy1 is offline   Reply With Quote
Old 03-04-2018, 10:01 PM   #5
Pontiacgurudan
The wiring looks pretty straight forward, the speedo is the newer one touch programmable. Put it in program mode, drive exactly one mile and press the button. That's it, no pace car, no dip switches, just a button. I'm going to hook all the necessary wires from the gauges to a large single plug I scavenged from a motorcycle wiring harness, then wire the other side of the plug to the truck that way my dash is one plug removable. The sending units are all standard single wire except the wires going to the speedo pickup. I'm combining the 90 ohm fuel sending unit included in the kit with my stock pickup in the tank. When I pull the bed off to install a suburban tank with the internal fuel pump, the Dolphin gas gauge will work with the later model sending unit. More pics to come.
