Old 11-14-2018, 10:26 AM   #26
v30crewcab
v30crewcab's Avatar
Re: Towing / Hauling thread.
Hauling a backhoe? you mean like this? no problem. any day of the week.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 11-14-2018, 10:30 AM   #27
v30crewcab
v30crewcab's Avatar
what about a 14K crane?
71 longbed 5.3 4l80
Old 11-14-2018, 10:33 AM   #28
v30crewcab
v30crewcab's Avatar
no idea what all this pallet racking weighed, but it felt heavier than the pieces of equipment for some reason. there's also a 4ft high stack of 4x4 plywood in this load also.
71 longbed 5.3 4l80
Old 11-14-2018, 10:53 AM   #29
stomper
Junior Member
stomper's Avatar
Are those Dodge rims? They look good. Bolt right up? What's your center cap?
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Gold White Fleetsides/Saddle
stomper is offline   Reply With Quote
Old 11-14-2018, 11:59 AM   #30
DieselSJ
Originally Posted by 100%Chevy View Post
What does a full size ,4 door ,big block dually weigh?
Towing it with my 78,C-10,250 six with 3 speed still on the column.
Mike.
IIRC, mine weighed in at about 6400 lbs
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 11-14-2018, 03:32 PM   #31
73kay
C10 pulling a K10.
Andrew
1953 3100 292 T5
1985 K5 Blazer 350 700R4 208
73kay is offline   Reply With Quote
Old 11-15-2018, 08:06 AM   #32
84 K30 hauling 12,500 lbs of granite gravel....
Old 11-15-2018, 10:25 AM   #33
Keith Seymore
Keith Seymore's Avatar
Let's see what I can find:
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-15-2018, 10:30 AM   #34
Keith Seymore
Few more:
1979-1986
1986 - 2019
Old 11-15-2018, 10:32 AM   #35
Keith Seymore
Precious cargo:
1979-1986
1986 - 2019
Old 11-15-2018, 05:46 PM   #36
Matt Man
Matt Man's Avatar
about 4500lbs
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 11-15-2018, 11:55 PM   #37
dieseldawg142
dieseldawg142's Avatar
mostly haul toys with mine...
all in, everything- a bit over 16 000lbs
not the heaviest load, 'bout 300 clams worth of empty beer and pop cans...
heaviest ever on my crew, 5 or 6 yrs ago my boss'es '79 1700 loadstar took a crap at the job with 5 tons of torpedo in it plus a 5 ton dump trailer hitched to it, also full. prob close to 30 000lbs.
flat towed it 5 miles back to the shop, was no effort even when buddy dropped it into 2lo to try bump start it
dieseldawg142 is offline   Reply With Quote
Old 11-17-2018, 05:09 PM   #38
SCOTI
SCOTI's Avatar
Contributing.....
This is the only pic of my current tow truck w/a load. Unfortunately, only the patient on the trailer was photo'd LoL.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-17-2018, 05:12 PM   #39
SCOTI
SCOTI's Avatar
My old 74 however did better when it came to photo op's....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-19-2018, 11:28 AM   #40
Rich84
Rich84's Avatar
The only thing I haul with my '84 is my lunch..
Rich84 is offline   Reply With Quote
Old 11-19-2018, 05:58 PM   #41
v30crewcab
v30crewcab's Avatar
they are dodge rims, with 2" spacers, 95-ish chevy threaded lugnuts and centercaps.
71 longbed 5.3 4l80
Old 08-29-2019, 03:26 PM   #42
stomper
Junior Member
stomper's Avatar
Picked this up for $100.
Do squares not haul as often as 67-72's. Thay have way more posts in their thread.
Old 08-29-2019, 05:06 PM   #43
sweetk30
sweetk30's Avatar
k30 doin k30 things .
free mulch grindings from local county compost lot . they even load them for you .
the only problem is you have to level them out were you dump them .
few more loads to go for the finish product to be done .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 08-29-2019, 05:12 PM   #44
stomper
Junior Member
stomper's Avatar
Damn that K30 barey squats with mulch cab high! I gotta get mine back on the road.
Old 08-29-2019, 05:32 PM   #45
SCOTI
SCOTI's Avatar
A little late night rescue a month or so ago. Timing gear went out/sheared the teeth on this regularly driven Model-A. It's owner is a 24yr old young man who knows them front to back & isn't scared to modify them so they can be driven.
But, in the end, it was maneuvering this load & the dually in the shop parking lot that killed my 7k mile rag-joint. Thankfully we were already 'home' so we were able to just band-aid it to get it parked so I could repair it later.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-29-2019, 05:41 PM   #46
sweetk30
sweetk30's Avatar
wellllllll there is a secret to that
timbren bump stops on 3/4 ton springs so it rides better than a k30 but has more weight hauling capacity over just the std k30 springs .
if i wanted i have a set of 4,400 lb HD springs i could install but then my ride would go to crap .
Old 09-09-2020, 09:55 AM   #47
stomper
Junior Member
stomper's Avatar
Estimated 4500 lbs. Old pump house foundation. Squat the K30 pretty good.
