11-27-2018, 08:39 AM | #1 |
Timing an 86 pickup
Is there a wire that that advances the timing that needs to be un-plugged before timing an 86 305? If so would someone please tell me where it is? Thanks
11-27-2018, 11:00 AM | #2 |
Re: Timing an 86 pickup
Far as I know, you just disconnect and plug the vacuum advance at the carb, then reconnect after your timing is done.
11-27-2018, 12:42 PM | #3 |
Thanks Bill.
One more question please. Which pointer on the timing indicator is 4 degrees before TDC? I can't clean the indicator unless I remove the water. Does anyone have a picture of a clean timing indicator? Last edited by Nickelcharlie; 11-27-2018 at 12:58 PM. |
11-27-2018, 01:24 PM | #4 |
Each mark on the timing tab is 2 degrees.
There’s a pic in here of yours. http://garage.grumpysperformance.com...dicators.1015/ |
11-27-2018, 09:22 PM | #5 |
Thank you very much geezer#99. Very informative article I found the picture I needed!
