07-16-2014, 05:44 PM | #1 |
1995 z71 a/c leak search
I've recently had my a/c stop working in my truck. I've replaced the low side accumulator switch, accumulator, low & high valve fill ports, most all of the seals. ran leak detector through it and found nothing around the r4 type compressor. will not hold a full vacuum at full pressure for long on the low side gauge on our machine. any ideas of where else could be leaking?
07-16-2014, 05:44 PM | #2 |
Re: 1995 z71 a/c leak search
also how long should i vacuum it down for? I've searched among many forums to no avail.
07-21-2014, 12:44 PM | #3 |
I got a cheap UV light on Amazon (about $7) and put the R134a with dye in it in one of my vehicles. Waited a couple of days and found I had a leaky hose.
The UV light makes it easy to find the leak. |
07-22-2014, 08:05 AM | #4 |
You could look ( or see residue ) on your hands by leaks.... it will look like a dark-ish oil / or seem like coolant on the lower areas?
'70 GTO Midnight Blue '88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany. '93 Cadillac STS Black '93 Mercedes SL 500 Teal '86 Yamaha FZ750 - 15,000 RPM '86 Yamaha FJ1200 - Criminally Fast 2016 Ferrari 488 GTB, I drive it - don't own it. '05 GMC Yukon XL , SLT 4wd ( just purchased 2018) |
