Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-06-2009, 01:33 PM   #1
Truword1
Voltage regulator removal
Hey group,
I'm looking for a write up on how to eliminate my voltage regulator and convert over to an alternator with a built in voltage regulator. Thanks, all you time and advise is greatly appreciated.
Thanks,
JD
Truword1 is offline   Reply With Quote
Old 10-06-2009, 01:46 PM   #2
El Jay
Gone to greener pastures
Re: Voltage regulator removal
I would do a "copy & paste" for you but my computer is AFU & won't copy.
Check out: http://67-72chevytrucks.com/vboard/s...dd.php?t=119379
It's a very easy to understand write up, with pictures done by toddtheodd on 9/122/0004.
If that doesn't work use the search tool & search for "external to internal voltage regulator conversion", or words to that effect.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 10-06-2009, 02:21 PM   #3
71tahoe
71tahoe's Avatar
Same FAQ I used and it worked great.
working link:
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
71tahoe is offline   Reply With Quote
Old 10-06-2009, 04:07 PM   #4
toddtheodd
The oddest Todd around
toddtheodd's Avatar
I used the same thing... and... wait... oh yeah...
God... was that really 2004... Doesn't seem like that long ago. No wonder when people ask me about it I can't remember the answers. LOL!
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 10-06-2009, 11:22 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
moved to the electrical forum, where there is a sticky FAQ thread with this info
Old 10-07-2009, 12:19 AM   #6
fixit-p
fixit-p's Avatar
Here's the way I like to do it, it's basically the same except with an extra splice at the voltage reg wiring and the wire from the #2 terminal isn't jumped to the alt post. It puts the voltage sense wire at the alt main splice.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 10-07-2009, 10:00 AM   #7
damnyankee36
damnyankee36's Avatar
Here's a page from my 69 Camaro color wiring diagrams I drew up a while back. I would imagine this would work on just about any late 60's, early 70's GM vehicle.
damnyankee36 is offline   Reply With Quote
Old 12-20-2009, 02:26 PM   #8
lyrikz
PITbut
lyrikz's Avatar
Im actually doing this RIGHT now today. I just had a question. Which wires do i jump on the alternator. From the diagram, i was going to jump #2 to power correct?
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 12-20-2009, 02:57 PM   #9
lyrikz
PITbut
lyrikz's Avatar
Also, is there a ground on the alternator. I dont see one. Just the post for the 12 volt and then the plug with the two wires.
and sold.
Old 12-20-2009, 03:06 PM   #10
fixit-p
fixit-p's Avatar
If you jump the wires at the regulator as shown you don't need to do any jumping at the alt. If you follow the #2 wire from the alt to the reg plug you'll notice that it's jumped to the red wire which goes to the circled area which is your alternator buss or junction connection that is where all you accessories pull power from, so you biggest voltage drop is at that point. The #2 terminal on the alt is the voltage sense wire and running it to the alternator buss connection would maintain peak voltage at that point (where you want it) Some simply jump #2 to the battery post on the back of the alt but that just maintains peak voltage at the alt and not the main splice so it wont perform as well. One of the best features of these alternators is their ability to monitor voltage remotely. HTH
Old 12-20-2009, 03:15 PM   #11
fixit-p
fixit-p's Avatar
The alternator is grounded through the case so no ground is needed for the alt to work but if you have the ground wire present you could connect it to the threaded hole on the back of the alt this would give the radiator support another ground path if it's still connected there but not required for alt operation just adds redundancy to the rad support and front light circuits
Old 12-20-2009, 04:43 PM   #12
lyrikz
PITbut
lyrikz's Avatar
Thanks, got it...
I sent you a pm on some other wiring maybe you could help me with...
and sold.
Old 12-20-2009, 05:05 PM   #13
Thealien
Thealien's Avatar
You can get a nice plug for your voltage regulator that does this for you
LIKE THIS ONE
Old 12-20-2009, 08:43 PM   #14
lyrikz
PITbut
lyrikz's Avatar
LIKE THIS ONE
I have the harness completely out of the truck, so i figured why not just rewire it.
and sold.
Old 12-20-2009, 10:05 PM   #15
Thealien
Thealien's Avatar
Just giving options. I bought an M&H harness and kept the external voltage regulator in case I or someone wanted to return to stock (yeah right) so I just installed the plug. I think for some it might be a better solution to some of the splices I've seen some make?
