02-21-2018, 03:08 PM | #1 |
Hi-Low Hump in late square?
So a thread in the for sale section got me thinking since I'm in the process of swapping a 4500 into my 85 k20 to replace the th400. Do the later squares have a removable hump and is there actually a low & high version? If so, what dictates the high vs low: 2wd/4wd or auto/manual? This was obvious on my 69 but I haven't pulled up the floor mat yet to have a look see.
02-21-2018, 04:17 PM | #2 |
Re: Hi-Low Hump in late square?
I'm swapping a NV4500 in place of a SM465 in my truck right now, 1986 K30 Crew. The 81 and up squares do not have a removeable tunnel. I don't know what dictates the high/low hump changes. I'm going to cut mine and make it removeable.
02-21-2018, 04:31 PM | #3 |
I'm hoping to just cut a hole big enough for the shifter: maybe the shift tower if need be. Cutting out the whole hump would require having another one slightly larger to cover the opening. That's why I was asking about the hi versus low or if it's all the same.
02-21-2018, 07:56 PM | #4 |
2wd auto trans or 2wd column shift manual = low hump
4wd or any floor shifted manual trans = high hump
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
02-21-2018, 10:57 PM | #5 |
TKCR- To the rescue as usual. Thank you for the clarification.
02-22-2018, 07:25 AM | #6 | |
I was contemplating cutting the hump out of my '86 and welding into the '79 to get the higher hump. But I have been told that there should be enough clearance for the bell housing. I think the high humps were designed to raise the shifters up closer to the driver. Whether it was the manual shift or a transfer shifter. So as for converting your automatic to manuall....the only think that I know of is that your shifter will set a couple inces lower and may not be as comfortable to shift. Could get a longer shift stick, but that would create a longer throw. All personal preference that I can see. But should all fit. |
02-22-2018, 09:53 AM | #7 |
73-80 have 2 different high humps...2wd and 4wd. Also, the floors are different at the rear of the high humps. The 4wd floors are higher than the 2wd where the removable hump meets the floor under the seat. 81-83 are bolt in high humps. 84 and newer are NOT bolt in.
02-22-2018, 09:54 AM | #8 | |
What TKCR said is correct about the high hump vs low hump for the 81-up trucks. I used a bolt in high hump from a 73-80 4wd truck when I swapped my 2WD Suburban to an NV4500. It took some serious hammering to fit the later floorboard (the floorboard seems to have changed shape a good bit when they got rid of the bolt in hump), but it eventually fit pretty well. There's a lot of photos of it in my NV4500 swap thread: http://www.67-72chevytrucks.com/vboa...d.php?t=610659 (scroll to post #17 for the re-uploaded photos) Just to reiterate, there's no way a NV4500 will fit without either using the 4x4/manual trans high hump, or installing a serious body lift. The photo below is a pretty good representation of how high an NV4500 sits relative to the rest of the floorboard: SunSoaked, you're good because your K20 already has the high hump. echo7bravo is going to need some mods to clear a manual trans in his swap.
86 Chevrolet K20/30 Suburban - 8.1/NV4500/NP205/Dana 60/14 bolt FF, build in progress 73 Formula - 400/Doug Nash 4+1, resto on hold 86 Chevrolet K30 3+3 - 350/TH400/NP241, Air Force/Forest Service Rescue Truck, for sale 01 Ram 2500 - 5.9L Magnum, daily driver 91 BMW 325i - Chumpcar series racecar |
02-22-2018, 09:54 AM | #9 |
for the early trucks at least there are two different high humps. A 4x4 and 2wd manual trans.
see attached.
1949 Chevy 3100 P/U http://67-72chevytrucks.com/vboard/s...d.php?t=302780 1976 GMC Sierra Classic C35 CCSB http://67-72chevytrucks.com/vboard/s...25#post8188825 |
02-22-2018, 09:55 AM | #10 | |
02-22-2018, 10:06 AM | #11 |
I’m no expert. Trying to figure things out myself. Only I’m not dealing with manual trans. I’m just trying to cab swap a rust free cab onto my 4wd. I think I am still going to have to cut and replace my hump with the one from my original cab if I can’t get away with a 1” body lift.
Posted via Mobile Device |
