Old 09-23-2018, 02:30 PM   #1
White halftrack
Rear bumper v43 rpo bracket question
Went to a swap meet today looking for a rear bumper for my 1987 crew and found one I am pretty sure. Guy says it was pulled off a truck and put in the shed a long time ago. I got it for 25 and was pretty thrilled to get it. My rpo code shows I should have a painted rear bumper v43.
My question is what do the brackets look like and where can they be bought? I did a google search and found many odd brackets but none that looked right. The bad bumper I have on there now has brackets that don’t look like a match.
Any help appreciated. I will get a rear shot of the bumper shortly.
White halftrack is offline   Reply With Quote
Old 09-23-2018, 09:32 PM   #2
White halftrack
Here is the back of the bumper
Old 09-24-2018, 06:06 AM   #3
Wgesnerjr
Wgesnerjr's Avatar
Re: Rear bumper v43 rpo bracket question
stock step bumpers and aftermarket ones have different mounting brackets. do yo know if this is a GM one or not? Did the seller indicate either way?
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 09-24-2018, 06:39 AM   #4
74CustomK20
74CustomK20's Avatar
My step bumper before I scrapped it just had 1/8" thick plates on either sides with just holes drilled in it to match the frame mounts.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 09-24-2018, 08:23 AM   #5
Dead Parrot
Just checked the SPID on my 75. It also has a V43 bumper code. It had a painted bumper similar to OPs but no tread plate on top and a plain flat back surface. It did have as a welded on part of the bumper, the two mounting plates to mate to the frame rails. Replaced with a heavier bumper. IIRC, I posted the old one up on the forum as a 'free to take' but got no interest so left on curb for trash day. There might be a pic of the old one if the OP's google fu is strong. Might show how the mounting plates were attached. Too many years ago, don't remember for sure.
That one is probably an aftermarket that had various mounting options depending on application.
Dead Parrot is offline   Reply With Quote
Old 09-24-2018, 10:59 AM   #6
Wgesnerjr
Wgesnerjr's Avatar
Here is a pic of the brackets from my factory V42 original rear step bumper. It utilized the chrome bumper bolts through the face, unlike the replacement I got through LMC. That alone might tell if it's an original or replacement.
LMC did say that the original brackets would not work on the replacement, and they didn't. So you may need the aftermarket bracket set from them to mount this one.
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 09-24-2018, 12:18 PM   #7
White halftrack
Old 09-24-2018, 01:22 PM   #8
White halftrack
Originally Posted by White halftrack View Post
https://lh6.googleusercontent.com/-zq61IB1VEcM/TzHv9R9bb_I/AAAAAAAAAMI/_cjG7iqlfpQ/s640/sc0224c6a7.jpg
That is the one I was looking at. I think it is oem or at least hope so. I like things original as I can even found an original scan seek stereo cassette. Thanks for thehelp. That pic was perfect on the mountain s.
Old 09-24-2018, 01:31 PM   #9
White halftrack
That pic of brackets is dead on. Thank you for posting.
I have now found all brackets except the C brackets in the pic. I tried posting a wanted but it says I am not authorized. Anyone have the pair of these.
Old 09-24-2018, 04:53 PM   #10
White halftrack
What is interesting is that it looks like the chrom bumpers have an additional brace on outside edge of bumper but the painted does not
Old 09-24-2018, 05:04 PM   #11
Dead Parrot
Found the give a way post with the bumper pic: http://67-72chevytrucks.com/vboard/s...d.php?t=635617
Sadly, didn't include an angle for the frame brackets. But they were basically vertical flat plates spaced to fit the frame and welded to the bumper.
Old 12-19-2019, 02:17 AM   #12
82Diesel
is that Chrome or painted. I cannot tell the picture... None the less I have what I believe to be a factory painted rear step bumper on my 1982 K10 I've only seen 3 other images online, 2 like mine and 1 the same... Since mine has brackets going to the bumper instead of the frame.
where can i find more info on this factory option? especially the RRO Codes for 1981+ ?
82Diesel is offline   Reply With Quote
Old 12-23-2019, 06:05 PM   #13
65chevysub
65chevysub's Avatar
Looks like the same bumper I have. It was in the bed when I bought the truck so assumed it was the original, and it is.
65chevysub is offline   Reply With Quote
Old 03-30-2020, 03:26 AM   #14
82Diesel
Here's my bumper i found local-ish to me i looked 7 months, it's the V43 Option as well with the Sideways out Support brackets paid $100 and got a Rust free set of Genuine inner fenders!!
Its a Painted Step bumper (Argent Silver)
