07-09-2012, 11:42 PM | #1 |
250 Inline 6 temp sensor ?
Hey guys, I am trying to locate the temp sensor on this truck but cannot find it. Did it originaly come in the coolant inlet hose ?
This is a 67 I6 250. Is this the coolant sensor ? Looks like maybe the PO drilled and tapped this new type of sensor ? |
07-10-2012, 12:04 AM | #2 |
Re: 250 Inline 6 temp sensor ?
Yep, that's the stock location for the sensor; routing of the wire looks stock as well. Terminal on the end of the wire is aftermarket but similar idea to stock.
07-10-2012, 12:59 AM | #3 |
Do you have a part # i just checked with autzone and they do not have this one. Also the way the wire is attached so the sensor is really cheap. Im sure it is missing something.
07-10-2012, 01:01 AM | #4 |
Found it
http://www.oreillyauto.com/site/c/se...RWD&vi=1321074 But it looks like it has a nipple at the end of it, how do you hook up that type of sensor ? What plug does it use ? |
07-10-2012, 08:34 AM | #5 |
In the link you posted, the AC Delco sensor also shows a pic of the electrical fitting. It slides over the "nipple" and snaps in place.
01-06-2016, 01:23 AM | #6 |
Frijolito, is the wire going to the sender original at any point? I was wondering 72 you can help me out and tell me what color is it and where does it connect into the firewall? Thanks
01-06-2016, 12:32 PM | #7 |
I just ordered a new temp sensor and oil pressure sensor from Rock Auto. about $10 a piece.
10-01-2018, 08:39 PM | #8 |
Thank you. Dealing with a new block, and forgot where it went.
1969 Chevrolet C20 Longbed I-6 250, SM465 |
