08-31-2018, 10:31 AM | #1 |
Headlight relay upgrade question
Guys, I would like to upgrade my stock wiring set-up for Headlight Relays, but not sure what kit to choose. I have sealed beams right now, ('68 C-10), and would like to install relays before I decide to upgrade lights, (if needed afterwards - I hear this change alone can improve brightness performance). Would really appreciate advice on what you may have used, and that you liked. Thanks in advance, Ned
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
09-01-2018, 05:42 PM | #2 |
Re: Headlight relay upgrade question
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
09-01-2018, 09:39 PM | #3 |
I got the same type setup from LMC. One of the relays went in a matter of days. I bought replacement relays from Summit and its been OK for a couple of years. I also got the lens gear for lamps to replace seal beams - major improvement.
Because of a LS conversion I reversed the intended direction and moved the relays to the driver's side. I took the harness cover off and ran the wires through the original side to side wire 'loom'. |
09-01-2018, 10:51 PM | #4 |
Thanks for the advice. I did order the LMC harness with 2 extra relays to have on hand.
09-03-2018, 09:33 PM | #5 |
Old member
I made mine for less than $10.00.
I rewire golf carts all the time so the wiring wasn't a problem.
10-02-2018, 04:51 PM | #6 |
I'm doing mine this weekend. I have about $15 in mine since I needed to buy some wire and replaced the sockets to the headlights. Any tips Andy?
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
10-04-2018, 11:33 AM | #7 | |
Old member
It's a pretty easy upgrade really. Take a test light and pull the head light connector off the drivers side light. With the test light on one of the contacts figure which wires are which...High/low. The drivers side connector works both lights. Then cut them about 12" away form the light. Take the end from the harness and this will be your trigger wire for the relay # 86 in the picture to the H beam one you are doing. Then the end to the head light goes to #87. You can run a #10 are #8 wire from the battery for the hot wire to the relays # 30 on both with inline fuse. Then ground each relay #85 to a good ground close to the relay. Repeat this for both relays.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 10-04-2018 at 03:34 PM. |
10-05-2018, 08:40 PM | #8 |
Put a set of H4 LED's in it instead of Halogen upgrades.
They are WAY brighter and do not require a Relay upgrade. |
10-07-2018, 11:23 AM | #9 |
Just finished my relay upgrade. Less than $15 since I already had the wire. New relays and headlight sockets. Now have 14 volts at the lights. Haven’t had a chance to drive after dark yet but they appear much brighter.
10-09-2018, 11:28 AM | #10 |
Old member
Now with the new brightness make sure you aim them good to get full benefit of them.
07-19-2019, 12:33 AM | #11 |
My new headlights with halogen bulbs passenger side burned out first time I drove at night (sheesh!). I'm doing what you suggest, I have ordered LED replacements. I figure with lower wattage I can avoid installing relays and LEDs shouldn't destroy themselves first time I drive my truck at night.
08-14-2019, 08:49 PM | #12 |
the relay upgrade isn't just about brighter lights . it takes a significant load off the mile and a half undersize wiring and headlight switch when going with modern lighting . if you take a voltage reading with a good meter you will see sometimes 10 volts or less depending on condition and age . the original lights would light no problem be it a little dull but those modern lights including those led like the full 12-14.5 if you want that life expectancy and brightness your looking for . if your buying a harness from lmc or any other you might want to upgrade to some good bosh 30 or 40 amp relays they will last much longer than the ones that they buy for super cheap and put in to keep cost down . even if your not doing a light upgrade its a worthwhile mod to take the stress off that 50 year old wire all the connectors and headlight switch . and dont forget to make sure those grounds are in great shape
