09-15-2020, 08:29 PM | #1 |
Rockwell T221 mounting adapter seals
Anyone have a part number for the two seals in the adapter that goes between the sm465 and Rockwell t221 transfer case. Local parts stores are having trouble getting me the right seals. The dimensions are 2.62" OD, 1.875" ID for both seals, but the one on the trans side is 1/2" wide and the other is like 5/16" wide.
09-15-2020, 08:40 PM | #2 |
Re: Rockwell T221 mounting adapter seals
It is sm420 and the Rockwell t221 tcase not a sm465
I do not recall the seal part numbers as it was in the early 90s i had mine apart last i do love the little bit extra low gear you get out of this pair over the 465 205 combo |
09-15-2020, 09:11 PM | #3 |
I stand corrected on the trans number. SM 420 trans.
09-15-2020, 09:36 PM | #4 |
Hold the phone! The T-221 was most certainly mated with the SM465 in '69.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
09-15-2020, 09:44 PM | #5 |
I have had 4 69 trucks they all had a sm420 with t221 tcase only trucks i seen with sm465 and a np205 tcase are 70 and newer or trucks that had been converted
One easy tell tail is sm420 front driveshafts is it has only 2 u joints Where the sm465 setups have 3 u joints two make up a cardan joint https://www.rockauto.com/en/catalog/...haft+seal,8416 |
09-15-2020, 10:11 PM | #6 |
Mine has 3 u joints for the front shaft. Either way I'm looking for the seal numbers for the adapter mount. Pretty sure it's a sm465.
09-15-2020, 11:24 PM | #7 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=796874
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
09-15-2020, 11:28 PM | #8 | |
09-16-2020, 03:39 AM | #9 |
GM did produce trucks with an SM465/Rockwell T221 transmission/transfer case in Model Year 1968. They may have also gone into MY '69 on GMCs and Canadian trucks.
I know there is such an animal, I have one as a core.
09-16-2020, 07:53 AM | #10 |
Hotcorner that seal is for a 2" shaft size. My coupler is 1.875". Do you recall what OD your coupler is?
09-16-2020, 09:15 AM | #11 | |
I’ll measure the coupler. I have an extra one in the garage.
09-16-2020, 09:19 AM | #12 |
Don't have a pic of the SPID handy, but both the SM465 and the T221 are on it: '69 Chevy K-10.
09-16-2020, 07:43 PM | #13 |
The seal part number for the transfer case mounting adapter are SKF brand 18581. It requires two seals. The number for the drive shaft seals on the transfer case are SKF 17387 or National 472164. Also requires two. Hope this helps someone in the future. All parts books or parts stores will tell you different. These are the numbers that cross reference to the seals that I removed. The measurements for the seals are 2.625" OD, 1.875" ID. The width really doesn't matter for this application.
09-16-2020, 09:09 PM | #14 |
The OD for my sleeve is 2”.
09-17-2020, 07:46 AM | #15 |
