Old 08-16-2020, 12:15 PM   #1
Nodnarb76
Nodnarb76's Avatar
R/F brake seized
A while back when driving,I noticed smoke coming from the R/F corner of my 87 Suburban. Once I stopped I noticed the R/F wheel area was very hot. I figured the Caliper was seized. I bought new calipers, rotors, and bearings. After we replaced all of that once we bled the brakes the R/F was still seized up. I have heard that the rubber hoses can come apart inside and not let the fluid flow back and cause the caliper to stick. It looks like my hoses are original/very old. Should I suspect this is my problem?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 08-16-2020, 01:17 PM   #2
jjzepplin
jjzepplin's Avatar
Re: R/F brake seized
Most likely. My daughters 2005 had that problem so not crazy to think you might.Hydraulics will push the fluid through but it can't return so the caliper will lock. Just turn the bleed screw and it should release and then lock again.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-16-2020, 02:52 PM   #3
Nodnarb76
Nodnarb76's Avatar
Thank you for confirming what I was thinking. I already have some new hoses. Just need to find time to replace them. Thanks again.
Old 08-16-2020, 06:27 PM   #4
Corts60
Just here to tinker
Corts60's Avatar
You're on the right track. It is most likely the hoses. I am about to replace mine as well.
