Old 06-06-2002, 08:10 PM   #1
72chev4x4
Question Dana 60 & 44 Axel Questions
I have a 72 chev 4x4 1/2 ton that i want to keep a half ton BUT i want, if possible, dana 60 fron and rear axel. did they make dana 60's in 6 lug for both front and back? or do i have to put a 6 lug dana 44 up front? thanks!
72chev4x4 is offline   Reply With Quote
Old 06-06-2002, 11:54 PM   #2
Scrub
Collector of rusty Items
Scrub's Avatar
Dynatrac makes dana 60 axles any way you want then except cheap.
http://www.dynatrac.com/series_60.html
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 06-07-2002, 12:26 AM   #3
diehardrider
KEEP IT PINNED
3/4 14 bolts in the rear and they are eight lug
diehardrider is offline   Reply With Quote
Old 06-07-2002, 01:53 AM   #4
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
if you got the bucks sure...... gotta be custom done
68SWB4x4 is offline   Reply With Quote
Old 06-07-2002, 08:37 AM   #5
misfits
misfits's Avatar
If you are going to get dana 60s why not just go with the 8 lug full floaters?
misfits is offline   Reply With Quote
Old 06-07-2002, 01:58 PM   #6
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
come on whatever high buck wheels you got on it now arnt worth the extra $$ spent on custom done dana 60s!
Old 06-08-2002, 12:42 AM   #7
72chev4x4
i have stock 6 lug rallye wheels on it and thats what i want on it. nothing, in my opinion, looks cleaners than rallyes.
Old 06-08-2002, 01:56 AM   #8
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
they make a similar 8 lug style rally....... http://communities.msn.com/68k10/68k...to&PhotoID=209
not as good but...... ALOT cheaper than custom axles
Old 06-08-2002, 12:56 PM   #9
72chev4x4
maybe i dont need custom axels? did dana ever make 6 lug dana 60's?
Old 06-08-2002, 09:01 PM   #10
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Dana-Spicer made a dana 60-2 that was a semi-float type axle that was under some GM C-10 trucks in 68-70, probably 6 lug. I believe some chrysler cars also had semi-float dana 60s.
If your looking to strengthen your drivetrain you could upgrade your axle shafts with aftermarket units(front and rear) and increase your front axle u-joint from the 260x to 297x.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-10-2002, 10:07 AM   #11
cheyenne10
cheyenne10's Avatar
I am familir with Dynatrac, seems to be the best and does have hefty price tag but worth it in some instances. Is anyone familiar with Boyce Equipment?
http://www.boyceequipment.com/axles.html
According to their website they have a lot of experience with truck axles and seem cheaper than dynatrac.
Bob
cheyenne10 is offline   Reply With Quote
Old 06-20-2002, 05:16 PM   #12
>X<
registered IWATA user
>X<'s Avatar
i ahve a dana 60 rear ff for sale if your interested, sean
(edited)
i decided to use this axle, sorry
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black
-'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end.
-01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny.
Take off that Von Dutch hat before i stab you with a 000 Mack.
>X< is offline   Reply With Quote
Old 07-06-2002, 11:25 PM   #13
sakohntr
sakohntr's Avatar
other 6 lug options
Dont forget that Chevy put 14 bolt corportate axles in there 6 lug
3/4 ton trucks in the late 80's and early 90's.
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
