Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 04-13-2017, 10:56 PM   #1
YoungPup1977
1972 blazer frame off project
Just wanted to post my next project which is a 1972 Blazer 4x4 frame off. Here it starts....
YoungPup1977 is offline   Reply With Quote
Old 04-14-2017, 08:47 PM   #2
YoungPup1977
Re: 1972 blazer frame off project
Progress on blazer....some body work and 700r4 rebuild...motor is on the stand...ZZ4.
Old 04-14-2017, 09:12 PM   #3
YoungPup1977
frame mock up with 700r4 transmission moving engine forward using the stock location of the Transfer case to reuse driveshaft original locations (no cutting of driveshafts) along with stock linkage being installed. Oh yea, used the advance adapter output shaft in the 700r4.
Old 04-19-2017, 10:02 AM   #4
72 paul
How close is your front driveshaft to trans pan, modifications there,any problems?Doing same. Trans is back home from build in couple days,double cardan may get in my way,ready to mock mine up as well. Thanks for any replies or moe pics.
72 paul is offline   Reply With Quote
Old 04-19-2017, 04:57 PM   #5
YoungPup1977
By using a stock pan, it will work ok. Not alot of clearance but I do not have to beat in the corner of the pan. With the driveshaft moving up and down will not hit the stock pan in any way....
Old 04-19-2017, 05:23 PM   #6
72 paul
Knew the reg pan would work but was curious if you mighta had to whack it on that corner or modify, Ill find out on my deal in a about week.Thanks,have fun.Paul.
Old 05-08-2017, 10:14 PM   #7
YoungPup1977
Stock trans pan works, no whacking or mods required. Thanks.
Old 06-20-2017, 11:06 PM   #8
YoungPup1977
Trans linkage for the 700R4
Old 01-21-2018, 01:00 AM   #9
YoungPup1977
update: 2018 progress
Old 03-12-2018, 02:24 PM   #10
YoungPup1977
New bed floor arrived. It’s a Woodall steel floor. Test painted on the front drivers fender. I think I like the color
All New brakes in the rear Along with a new gas tank
Old 03-12-2018, 02:30 PM   #11
YoungPup1977
Welded in a factory AC dash.
Old 03-19-2018, 11:01 PM   #12
YoungPup1977
Sand blasted and painted the rear diff. Posi and 3.73 gears are being installed along with all new bearings.
Old 03-20-2018, 01:24 PM   #13
CTENTA1
Registered 1971 K5
Cool.
CTENTA1 is offline   Reply With Quote
Old 04-14-2018, 12:23 AM   #14
YoungPup1977
Sold blazer !!!!!
Old 04-03-2019, 09:05 AM   #15
YoungPup1977
I figured I would use this same thread to use for my 1971 blazer 4x4 frame off restoration. So here it goes :
Old 04-03-2019, 09:30 AM   #16
YoungPup1977
I finished the np205 transfer case
Old 04-03-2019, 07:47 PM   #17
jaros44sr
jaros44sr's Avatar
Orange looks cool, may steal that!
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-03-2019, 11:37 PM   #18
YoungPup1977
Installed the np205 with 700r4
Old 04-04-2019, 10:42 AM   #19
YoungPup1977
Power steering installed
Old 04-04-2019, 10:51 AM   #20
YoungPup1977
Engine set into frame. Looking to get headers bolted in. Not sure exactly which headers I am going to go with at this time. I have some used ones bolted up
Old 04-07-2019, 12:59 PM   #21
CO71Blazer
I read these threads and I am just amazed how y'all just take your trucks apart. I have a fair amount of mechanical ability. I can turn a wrench, I can weld (with the help of a good grinder) and I have an eye for detail. But taking my truck down to the frame scares me more than a little. But y'all give me hope. I love it. Now, all I need is a place to work, as my one car garage won't cut it.
CO71Blazer is offline   Reply With Quote
Old 04-09-2019, 06:33 PM   #22
YoungPup1977
Sandblasting the windshield frame next.
The cargo floor and step down cross member in place
The complete front floor pan is on order and should show up at the shop tomorrow.
Old 04-09-2019, 06:41 PM   #23
YoungPup1977
For those who are crazy about tow hooks. I thought I would share my next 1972 blazer 4x4 extreme bend tow hook project. Lol !!
Old 04-09-2019, 06:58 PM   #24
YoungPup1977
New gas tank. How bout that filler neck
Old 04-19-2019, 11:03 AM   #25
YoungPup1977
Removed floor.
