04-29-2003, 10:13 PM | #1 |
Driveshaft support bearings
Well I am having problems keeping the driveshaft support bearings from breaking. I go through about two to three a summer. I just replaced one last weekend because all of the rubber around the bearing was shredded. I went for two drives since then and tonight the spotwelds on the metal plate that hold up the bearing broke. I am pretty sure that this was a defective driveshaft support because I just went over a set of railroad tracks and then it started banging underneath the truck.
I have a 350 in the truck with a turbo 350 tranny the motor is built up I would say around 325 to 350 horsepower or so. I am sure that this is part of the problem. My question is that could it be that the driveshaft is out of balance? Or do a lot of you guys have the same problems with these driveshaft supports? Is there anything that I can do to prevent this problem or is going to just keep on happening? Thank you for any help Cameron |
04-29-2003, 10:20 PM | #2 |
Guest
Posts: n/a
I think your driveshaft is either out of balance so much that its destroying the bearing, or maybe its dented or has a nice piece missing from it.
04-29-2003, 10:24 PM | #3 |
Nothing fits but the oil
Sounds as if you have a bunch of horsepower and torque going into a very tall rear axle (3.08 maybe?) On a two piece shaft, there is an awful lot of twist and on mine I support welded where the spot welds were and it's been solid as ever.
Land of the free Because of the brave |
04-29-2003, 10:26 PM | #4 |
"See the U.S.A....."
I had this problem too.
I welded a brace to the bottom of the bearing housing and secured it to the trailing arm bolt. I'll Take a picture of it tomarrow
and post it here for you. Its not pretty but it works! This is what used to happen.
1970 short bed fleetside 1949 all origional chevy 3600 1974 camaro Richmond , Texas(just S.W.of Houston) |
04-29-2003, 10:31 PM | #5 |
I have 3.73 gears in the rear that are a one wheel wonder no posi or locker or anything like that with 295/50/15 radial ta's on the back
04-29-2003, 10:37 PM | #6 |
Is it lowered?
04-29-2003, 10:43 PM | #7 |
Have a friend who races an 11 "something" second drag truck.
He still uses a 2 piece driveshaft. He shoots it full of Sylicone. Don't know how he does it, but I'll try to find out if you are interested. |
04-29-2003, 10:44 PM | #8 |
I meant the carrier bearing. Getting tired here.
04-29-2003, 10:45 PM | #9 |
Radical Cam,
I have the same bearing as you and have had no problems. I run a 3.73 gear one-legger with a 390 hp (dyno) 383. I don't see why you have a problem unless like you said, the shaft is out of balance or possibly the pinion angle is not correct if someone replaced the rearend. Just my 2 cents James |
04-29-2003, 11:27 PM | #10 |
Well the truck is not lowered yet it is at stock height but I am going to lower it 2.5 in the front and 4 in the rear. I am going to try and find another driveshaft somewhere and put a new support bearing in it and new U-joints and then we will see how that is.
