Old 03-13-2018, 01:06 AM   #126
toolboxchev
Re: Let's play name that part, bolt, harness, screw....
Originally Posted by John H. View Post
How about these two pieces?
Attachment 1762998
tool box
toolboxchev is offline   Reply With Quote
Old 03-13-2018, 01:30 AM   #127
John H.
John H.'s Avatar
Your name says it all metal and wood floor adjustable brackets.
John H. is online now   Reply With Quote
Old 03-13-2018, 10:03 PM   #128
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Larger ones with shoulder are door lock to door screws.
Yep. Door latch to door.
Originally Posted by Curtb1971 View Post
Are the small ones are for wiper transmission to inner cowl?
The smaller versions are used to affix the lift gate strut to the lift gate on K5s.
Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, AASmedic, SoCoC10, Lumaestas, carbuff382
Old 03-22-2018, 12:22 PM   #129
bob8619
Is this a fuel pressure regulator or what?
1968 C10
bob8619 is offline   Reply With Quote
Old 04-02-2018, 08:53 PM   #130
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Attachment 1766414
In line pump?
Anyone know where these seals go? I know generally but not the exact spot.
Old 04-03-2018, 01:29 AM   #131
stsalvage
Scrapper 1
stsalvage's Avatar
that Excssery bolts have so many uses.I now use them as new ground location's all over your truck makes it easier to get to and i can add more then 1 ground to the bolt.Plus if i need to use both sides in the cab i can cleans up my grounds.I have them for metric bolts and standard and fine tread.its all about making my life easier.
But the one i never see you guys showing on this whole site is the AC bracket for a 250 or a 292 Inline 6 I know nova's had them so did impala's But for the life of me never seen a chevy or GMC truck with AC with a inline 6
seen it with the 305 V6 so show me some inline 6 with AC from 1960--72.they are harder to find then the rarest GMC 1 ton short bed or the crew cab 4 door 1960--72 trucks.i've never seen any pics with the factory AC with that big A6 compressor
stsalvage is offline   Reply With Quote
Old 04-05-2018, 08:39 AM   #132
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I believe this is the correct location for these seals....
Old 06-16-2018, 10:00 AM   #133
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Ok - anyone recognize these springs? Seven inches long...
I need two more please
Old 06-16-2018, 10:16 AM   #134
SoCoC10
SoCoC10's Avatar
Parking brake cable retainer springs?
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
65' Malibu SS Azure Aqua, Steel block LS3, 200R4
SoCoC10 is offline   Reply With Quote
Old 06-16-2018, 10:17 AM   #135
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Originally Posted by SoCoC10 View Post
Throttle return springs?
Nope. Here's a hint: two per vehicle.
Old 06-16-2018, 10:31 AM   #136
SoCoC10
SoCoC10's Avatar
I demand a recount! I changed my guess before you replied!
Old 06-16-2018, 01:03 PM   #137
bill3rail
bill3rail's Avatar
Here are a few loose connectors I found while working under the hood.
These two could be almost anything...
This one however is totally unknown to me... Initially I thought proportioning valve wire, Nope! My proportioning valve has a female plug.
Side View
This one is easy, however my truck does not use this type of connector because it has an external regulator.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
