Old 03-13-2012, 04:36 PM   #1
Lugnutt
Lugnutt's Avatar
1972 Automatic Column Shifter Stiffness
Hey guys, I hope one of you can help.
I'm restoring my 72 Chev 4x4 that I've had since new and one of the things that has happened over the years (can't remember when) is that the transmission column shifter has gotten real stiff and hard to move around from Park into the various gears and back again. Do any of you have a guess where I might start looking for the cause of this stiffness? Maybe this has happened before to one of you and could share where the problem was.
I appreciate any input, thanks,
Gary
Lugnutt is offline   Reply With Quote
Old 03-13-2012, 05:10 PM   #2
storm9c1
*** That's interesting ***
storm9c1's Avatar
Re: 1972 Automatic Column Shifter Stiffness
Unhook the linkage in the engine compartment at the firewall. Get inside and move the shifter. See if the lever moves freely then. If so, then it's in the linkage going to the trans and not the column. One note: if you have a tilt column and you have the long pointer, remove it so it doesn't get broken. I don't remember when the column changed.
Next step is to unhook the trans and move the lever by hand. If that is stiff, then it's inside the trans. Otherwise you can work the linkage by hand and see if that's stiff. If it's a problem with the linkage rods, chances are they just got rusty on you and need some TLC.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L (6K miles)
1995 Chevy Caprice 9C1 (177K miles)
1994 Chevy Caprice 9C1 #3 (99K miles)
1995 Chevy Caprice Wagon #2 (60K miles)
1995 Chevy Impala SS (20K miles)
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 03-13-2012, 05:49 PM   #3
cdowns
cdowns's Avatar
i'd start by spray the heck out of the shifter tube on the column with wd40 or simaler stuff// i've found 40year old moving parts respond well to cleaning and lubrication
Old 03-13-2012, 06:26 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
Gary
I had this happen on mine. Spraying worked temporarily but I had to take it out and disassemble it, clean out the old grease and metal grindings, regrease it and put it back in. Has works fine for 2 years now.
dwcsr is offline   Reply With Quote
Old 03-13-2012, 07:30 PM   #5
Lugnutt
Lugnutt's Avatar
Thanks for your input on this. As I'm messing with it it feels like the stiffness has more to do with pulling the shifter back, like you would do to release it out of park. That sounds more like steering column to me as some of you suggested. I've never had the steering column out before, does it disconnect at the joint just below the shifting arms? Are there any links you guys know about showing this procedure? I like being prepared before I dive into repairs.
Thanks all for your help,
Gary
Old 03-13-2012, 07:45 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Thanks for your input on this. As I'm messing with it it feels like the stiffness has more to do with pulling the shifter back, like you would do to release it out of park......Thanks all for your help, Gary
Yeah, that's exactly what happens when the grease in the column gets old and hard. Mine was so bad (Texas heat) that I had to take the column off and dismantle it. Litteraly chunks of caked up grease fell out. I cleaned and relubed and worked like new.
You may not have to take it off. Some guys have had success by doing what's mentioned above. Just be patient and let the lube work. You'll have to spray the hell out of it so be sure and protect the carpet or floor pan with towels.
68gmsee is offline   Reply With Quote
Old 03-13-2012, 07:55 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Read through this posts and be sure not to force it too much cause the shift levers have been known to break. You may have to remove the steering wheel and all the internal turn signal parts and bearings, etc. for easier access. Just take pictures and keep everything in order.
http://67-72chevytrucks.com/vboard/s...d.php?t=465107
Old 03-13-2012, 08:12 PM   #8
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Gary......if this lasts longer than 4 hours, please go to the doctor.
prostreetC-10 is offline   Reply With Quote
Old 03-13-2012, 11:44 PM   #9
Lugnutt
Lugnutt's Avatar
Yea, just got back from the doctor, he said my lube got too old.
Old 11-16-2013, 11:00 AM   #10
ChillWinstonC20
ChillWinstonC20's Avatar
I know this thread is old but <amazingly> the great advice holds up. Thanks all!!
ChillWinstonC20 is offline   Reply With Quote
Old 11-17-2013, 07:37 PM   #11
68gmsee
Active Member
68gmsee's Avatar
Great that it helped.
The one thing I have found out is that regardless of the problem with these old trucks, someone has experienced it. Lots of good info in here from some very knowledgeable folks.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
Old 05-29-2014, 02:17 PM   #12
totem
Thank you so much for the WD40 suggestion! It worked for me in about a second after spraying the shifter lightly so it dripped along the tube into the column. I was thinking I needed transmission work done and was not happy about it. My 72 Chevy van has never been so easy to drive, not since I've had it anyway. I had no idea it was actually supposed to be so easy to shift. It had gotten so stiff, it actually hurt my arms to get it into park and reverse. Thanks!!!
totem is offline   Reply With Quote
Old 10-09-2015, 04:09 PM   #13
gkhashem
I know this is an old thread, but a few sprays of WD-40 and it freed up real quick!
Thanks for the tip. Seems to really worked and almost instantly.
gkhashem is offline   Reply With Quote
Old 10-14-2015, 05:43 PM   #14
BigandBlue72
My auto column shifter had the same issue. I sprayed the inside with white lithium grease. One pull back on the shifter and she was freed up.
I got fun.....You want some?
BigandBlue72 is offline   Reply With Quote
Old 03-12-2018, 12:33 AM   #15
Detmar
Detmar's Avatar
2018 and this worked like a charm.
Detmar is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
