Old 03-09-2013, 01:07 AM   #26
Captainfab
60-66 Nut
Re: vortec on a gen 1 small block questons.
Here are some pics of what I have been talking about, so some of you can better visualize it.
The first pic shows the thermostat bypass from the water pump boss up thru the deck surface of the block. I ran a piece of welding wire thru the passage.
The next pic shows a Vortec head which is missing the corresponding hole in the deck surface of the head. This is shown with the red circle.
The last pic shows a regular SB head (happens to be a TBI head) which does have the corresponding hole. This is indicated with the red arrow.
I do not know if this bypass passage is necessary or makes a difference, but I believe it deserves consideration.
Old 03-09-2013, 01:47 AM   #27
ol'blazer
ol'blazer's Avatar
great pics, thanks a lot! i will look tomorrow. again thanks for all the help!
Tyler
1980 2wd blazer
1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276
1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784
ol'blazer is offline   Reply With Quote
Old 03-12-2018, 12:25 AM   #28
Richard2112
Considering doing this also. Vortec heads/manifold instead of motor swap.
Richard2112 is offline   Reply With Quote
Old 03-12-2018, 09:07 PM   #29
garyd1961
If you have your heater core hooked up you don't need to drill a bypass. If you aren't running a heater just run a bypass heater hose from your intake to your water pump and you still don't need to drill .
garyd1961 is offline   Reply With Quote
Old 03-12-2018, 09:49 PM   #30
Jrainman
Jrainman's Avatar
Agree 100%
Jrainman is offline   Reply With Quote
Old 03-13-2018, 12:55 PM   #31
Tom
driving is in my blood
Tom's Avatar
Wow, I've been running vortecs since 1998 and I never knew about this bypass hole. Cool stuff.
-06 CBR600F4i: 110mph in 2nd at 14,000rpm= happiness.
-02 Suburban 4x4: stock
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
