Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 02-20-2018, 11:48 AM   #1
GM man
GM man's Avatar
No voltage from PCM fuel relay trigger
This came out of nowhere. I've had it hooked up for several months now and it's worked really good. Now I'm not getting any voltage from my PCM trigger to my fuel pump relay. If I wire around it, the fuel pump kicks on. I've been all over checking wires, fuses, grounds, etc.. and this is baffling me. In a desperate measure, I tried replacing the crank sensor and still nothing. I've read where guys have encountered this kind of issue theirs wound up being wired wrong or a grounding issue. I haven't changed anything up, so I'm at a loss.
1972 GMC Jimmy 6.0/4L65
1972 Chevrolet long bed 1/2 ton
GM man is offline   Reply With Quote
Old 02-21-2018, 03:34 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: No voltage from PCM fuel relay trigger
This is a little out of my league but I kinda understand it. I checked google and found this site with the same problem you are having so I am pasting the link for you.
http://www.pirate4x4.com/forum/gener...fuel-pump.html
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-21-2018, 06:24 PM   #3
87Skier
87Skier's Avatar
I think is issue is one of two places. Either an ECM issue, or a wiring issue.
It sounds like you have the wiring figured out. Should have 12 v fused power to relay, good ground, wire to fuel pump, and the ECM signal.
On the ECM side, there could be something that is preventing it from powering up the fuel pump. Like a fault code. Might want to try checking codes, then resetting the computer by disconnecting the battery.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 02-22-2018, 01:35 PM   #4
GM man
GM man's Avatar
Well I got it going. Cannot tell you what was wrong as I didn't replace anything. The wires I cut while trying to diagnose the issue, I re-soldered and heat shrinked and all of a sudden it's working again. Makes no sense. I've taken my time and carefully inspected every wire, no cuts or slices in any of them to ground out anywhere...I was fixing to get another PCM or just put the fuel pump on a switch, but now it's fixed. Thanks for the help anyway fellas.
Old 02-22-2018, 05:51 PM   #5
Wrenchbender Ret
If there is a problem with the ignition the ECM won't kick in the fuel pump.
Wrenchbender Ret is offline   Reply With Quote
Old 02-22-2018, 06:57 PM   #6
GM man
GM man's Avatar
Yeah, I read somewhere that if the crank sensor goes bad that the PCM won't kick the fuel pump on. I replaced it and nothing changed. I could hear the throttle body do it's deal when the key was on, so I'm assuming my PCM was still getting power.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
