Old 02-25-2018, 08:55 PM   #1
70zz4
zz4 missing bolt hole in pass. head for serp sys.
any advice on drilling new hole in head ,for proper loacation &trueness
70zz4 is offline   Reply With Quote
Old 02-25-2018, 09:08 PM   #2
B. W.
B. W.'s Avatar
Re: zz4 missing bolt hole in pass. head for serp sys.
Use the accessory bracket as a guide.
B. W. is offline   Reply With Quote
Old 02-25-2018, 09:42 PM   #3
70zz4
yes my thought also ,however iam concerned about holding true 90 degrees from the head , maybey iam just over thinking it.
Old 02-25-2018, 10:35 PM   #4
B. W.
B. W.'s Avatar
Spot drill the hole using the bracket. Remove the bracket & use a 90 jig to drill a pilot hole. You can buy a commercially made one (they don't cost a lot) or make one from a block of wood. use a drill press to drill the hole through the block so it is at a perfect 90. Once the pilot hole is drilled square you can drill up to tap size by hand. (you could just drill the final tap size to start with & be done with it, I feel more comfortable drilling a pilot hole first.)
Old 02-26-2018, 03:12 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I did this. Used the bracket to lay out the spacing.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 02-26-2018, 04:43 PM   #6
weq92f
What about the depth? Surely have to be careful there eh?
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 02-26-2018, 06:19 PM   #7
jjzepplin
jjzepplin's Avatar
Done this twice. No bigge. Even if you drill too far you can use a stud and some RTV. Your water pump bolst go thru the block don't they. I used a stop on my bit but it slipped... HIt the water jacket and just RTV'd it and has never leaked yet. Happened on both engines as the castings for the head can be different. I used the bracket as the guide and a long bit.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 3.73 posi-4-speed Saginaw-307-no budget build.
58 Belair http://67-72chevytrucks.com/vboard/s...d.php?t=756563
jjzepplin is offline   Reply With Quote
Old 02-27-2018, 08:50 PM   #8
70zz4
ok thanks for the info, & to any others who chimed in. hoefully have time this weekend.
Old 02-28-2018, 08:40 AM   #9
95 S_Trucker
95 S_Trucker's Avatar
If you do drill into the water jacket, I would use thread sealant insted of RTV(Permatex 59235). It will make it easier if you need to remove the accessorie bolts. It wont leave dried chunks or RTV in your engine.
-99 K2500 LS CCSB 7.4
-11 GMC 2500HD SLE CCSB 6.0
-96 C3500 HD 7.4 NV4500 Rollback
-85 K10 5.7 700r4
-78 K10 5.7 4 Speed
-90 ZR1 5.7 6 Speed
-62 Lincoln Sedan 430 Auto
-61 Lincoln Convertable 430 Auto
85 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=368864
78 Big10 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=383629
96 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=614515
95 S_Trucker is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
