Old 03-12-2018, 08:33 AM   #1
botoepfer
Junior Member
botoepfer's Avatar
help to ID these motor mounts
hello I am planning a swap installing a 292 in the place of a 230, here is the 292 engine with a mount parts I can't ID,
I picked these towers up Sat.
botoepfer is offline   Reply With Quote
Old 03-12-2018, 10:59 PM   #2
Captainfab
60-66 Nut
Re: help to ID these motor mounts
The brackets on the engine are for a '73-'87 truck. You will need to replace those with the correct brackets for a '63-'72 292 if you are to use those motor mount brackets you have. The other option would be to find the frame side engine mount brackets for a '73-'87 C20 or C30 with a 292. Those will fit the early frames pretty close.
Old 03-13-2018, 09:45 AM   #3
botoepfer
Junior Member
botoepfer's Avatar
Thanks John being its going in a 63 I guess I better hunt up the rest,, do you know if the parts that mount to the engine are different than those on the 230?
Old 03-13-2018, 11:25 PM   #4
Captainfab
60-66 Nut
I can't say for sure but I think the 292 uses different brackets on the block. I'm not that familiar with the I6's. You might need to ask a question here specifically about that for a definitive answer.
Old 03-14-2018, 10:53 AM   #5
botoepfer
Junior Member
botoepfer's Avatar
My buddy found these for his 4x4.. Looks like a pipe sleeve on the Pass side !
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
