Old 12-08-2010, 12:43 AM   #1
dash13
Keeping my I6 250...what to do?
I am keeping my I6 250 and want to know what to do to it. I have changed plugs and wires and replaced the valve cover gasket. Replaced the fuel filter and did an oil change.
What's next?
dash13 is offline   Reply With Quote
Old 12-08-2010, 01:09 AM   #2
dash13
Re: Keeping my I6 250...what to do?
Here are some pictures of it now.
Old 12-08-2010, 01:20 AM   #3
TwoFiftyShifter
Are you looking to do some modifications? You could look at buying some headers to do dual exhuast and let her breathe a bit better, change from your points setup to an HEI unit. That's all I've done to my 230 yet.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 12-08-2010, 01:29 AM   #4
dash13
Explain the Points to HEI and why one would change.
Old 12-08-2010, 01:34 AM   #5
68lwb292
Ex-Minitrucker
68lwb292's Avatar
Definitely get an HEI look for late 70s straight sixes in the junk yard (Novas, Camaros, Malibus, & pickups) or get a new one (Ebay $60-$120). They are 100% more reliable. Dual exhausts sounds great on these motors, and an intake, carb, and cam swap will wake that little guy up too. Check out Clifford Performance if you wanna get hooked and spend all your Christmas money!
http://www.cliffordperformance.net/M...gory_Code=C250
68 C10 LWB 292 4spd
68 C10 LWB 250 3spd
68lwb292 is offline   Reply With Quote
Old 12-08-2010, 01:37 AM   #6
ol_skool_chevy
ol_skool_chevy's Avatar
1. HEI unit. ignition coil into the distributor cap, eliminating the need for a coil wire and adjusting them. HEI's produces both a hotter and fatter spark', huge HP gains.
2.2 barrel carb intake "more fuel flow"
3. go to pick and pull and get a new model exhaust manafold from a inline 6...maybe out of a truck of the 1980-85. they are 1/2" bigger....its like running a header..and run 2 1/2" mufflerand pipe.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 12-08-2010, 01:39 AM   #7
68lwb292
Ex-Minitrucker
68lwb292's Avatar
HEI is way more reliable and produce a hotter spark. You'll have to probably run an ignition hot 12V to power it up because I think the points coil is low voltage. They are 1 wire hook up and easy tach hook up too. Plus they are a cleaner look than the points set-up.
68 C10 LWB 292 4spd
68 C10 LWB 250 3spd
Old 12-08-2010, 01:46 AM   #8
dash13
This all sounds great.
Old 12-08-2010, 01:59 AM   #9
68lwb292
Ex-Minitrucker
68lwb292's Avatar
Keep us updated on what you get done. We all have to stick together cause Inliners are like Mopar Guys ........ Crazy and Outnumbered!
68 C10 LWB 292 4spd
68 C10 LWB 250 3spd
Old 12-08-2010, 02:14 AM   #10
dash13
I can do that. And I certainly notice that
What kind of gas mileage should I expect once I'm driving my truck?
Old 12-08-2010, 02:17 AM   #11
68lwb292
Ex-Minitrucker
68lwb292's Avatar
Depends on gearing and trans but don't expect over 16
68 C10 LWB 292 4spd
68 C10 LWB 250 3spd
Old 12-08-2010, 06:17 AM   #12
Shaky
Six in a row makes it go...
Shaky's Avatar
As everyone else said - you have to go electronic. Better starting, more power, easier maintenance, better mileage.
I've pulled off 20 mpg with a 250 before on a steady cruise, but 16-18 is the norm for me.
If it's a '67 250 I usually update to the '68-'72 monojet.
You might want to pop a side cover, pull a lifter and look at the cam lobe. If it looks worn it's not too hard to put a new cam in and it will really wake it back up...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 12-08-2010, 10:59 AM   #13
camrycurt
camrycurt's Avatar
Will the 80-85 manifold fit on a mid-sixties 230 L6?
I think GM stopped making the 230s around 1970 or so, and mine needs a new manifold. If a newer and better model out of a bigger L6 would work I'd love to make this change.
Thanks!
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 12-08-2010, 03:21 PM   #14
dash13
You might want to pop a side cover, pull a lifter and look at the cam lobe. If it looks worn it's not too hard to put a new cam in and it will really wake it back up...[/QUOTE]
Tell me more......
Old 12-08-2010, 03:27 PM   #15
ol_skool_chevy
Thanks!
The exhaust manafold will fit....I have one
Mark with Chalk
Cut with a torch
Old 12-08-2010, 03:40 PM   #16
Luvlegs
Luvlegs's Avatar
For future mods (not just the engine) you can go to power steering (pump mounts are harder to find) and brake booster (you'll need the also harder to find offset air filter set up). Both of these are just things to tinker with but keep you looking for I6 parts. Hoses and wiring are things to go through as well. Everything thats black in the pic is new stuff on mine.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 12-08-2010, 05:20 PM   #17
Shaky
Shaky's Avatar
Tell me more...... [/QUOTE]
Well, '68 was when the redesigned monojet was introduced. I've found it easier to work on and it performs well. It's a direct bolt-on so I did that to my '67.
I had a '70 Bel Air with a 250 that was not well maintained. It ran, but didn't have a lot of power. I popped a lifter out and looked at the cam lobe. It was worn way down.
For not much money I got a stock replacement cam from JC Whitney and popped it in. Now the valves opened all the way . Made a noticeable difference in power.
Old 07-25-2017, 10:14 AM   #18
stevenfromtexas
stevenfromtexas's Avatar
i got excited when i saw this picture!! i thought mine was actually road worthy hahaha
i did the petronix system in my distributor. i wanted to keep the look of the coil (the original look)
stevenfromtexas is offline   Reply With Quote
Old 07-25-2017, 10:21 AM   #19
stevenfromtexas
sorry if this is sideways too
Old 07-25-2017, 10:45 AM   #20
cericd
cericd's Avatar
Just an FYI, if you want your photos to upload with the proper orientation, when taking a picture...
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 07-25-2017, 10:50 AM   #21
cericd
cericd's Avatar
If you have photos that you have already taken with the home button on the left, top or bottom, they will have to be rotated in a piece of software to correct the issue. Even though the appear to be right-side-up on your phone or computer any vBulletin forum (like this one) will not display them properly.
If you would like to know more about how to correct the orientation of images you've already taken please see this post http://67-72chevytrucks.com/vboard/s...d.php?t=743225
Chris
Old 07-25-2017, 02:47 PM   #22
RichardJ
In '79 the 250 became known as the 4.1 liter Pulsair with integral intake and totally different exhaust manifold. The manifold (80-85 ?) mentioned would have to be from a 292 and not all 292's. It is larger with 3-bolt outlet, but very hard to find and not worth the effort to change the exhaust system for marginal if any improvement.
If you want to change the exhaust, get tube headers and run dual exhaust all the way back.
That change alone to the engine will still give only marginal improvement. You still have a 8:1 cr and not exactly a performance head.
If you are able to adjust points properly and have a dwell meter, keep the stock distributor. The HEI has two advantages. You don't have to adjust or replace the points every 10,000 miles and it will provide a better spark over 6,000 rpm. OK, three, it will fire old, dirty, misadjusted spark plugs, long after their usable life with a points ignition. A remedy is to check and clean every 10,000 along with the points.
It won't give more power or fuel mileage than a well maintained point ignition.
25 years ago I installed an HEI, because my truck was my daily and only driver. I was driving 60 miles a day for work only and the interval for the points needing attention was more frequent than I had time for.
If you want to make changes that will put a smile on your face and make you want to get behind the wheel, add power steering and AC.
These are notable, worthwhile improvements that give the biggest bang for time and effort.
The next thing is gearing. That can be corrected with new rear gears or depending on the current gears, possibly with an over-drive trans.
Unless that has already been addressed, you're probably driving the slow lanes or side streets. Get the right gears /trans and get out on the highway and enjoy.
The one thing that you haven't been told is that the sky will fall if you don't change the Alt to a Internally regulated Alternator. B.S.
I have AC, HEI, electric fan, elec brake controller, Bluetooth stereo and stock alternator.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 07-25-2017, 08:05 PM   #23
Dirt's72
What's next?
Has your motor been rebuilt? Sure is clean.
Dirt's72 is offline   Reply With Quote
Old 07-25-2017, 10:33 PM   #24
stevenfromtexas
thank you very much for the picture advise....several of the pictures were taken before the tips..
thank you again
Old 07-26-2017, 08:06 AM   #25
Mike C
Mike C's Avatar
I agree with many posters above. HEI (Pertronix OK, but if a failure, HEI parts available inexpensively anywhere around town same day.) Power Steering. I'm OK with manual brakes, even discs but YMMV.
But the best thing you can do for your 6 cylinder is a T5 transmission from an S10 with a 4.3.
I really like the way a lowered truck rides as well. Drop kit, swaybars and gas shocks and my '69 is a pseudo-sports car.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
