Old 01-13-2019, 03:57 PM   #1
cgster
Changing from Auto floor to column shifter
I bought a 72 truck that has an auto B&M floor shift in it. I'd really like to get a automatic column and move to column shift. My question is, how hard would this be to do? Would it just require the auto shift column and a lokar transmission linkage rod kit to make this happen or is there more things needed?
cgster is offline   Reply With Quote
Old 01-13-2019, 07:43 PM   #2
Smitty
Smitty's Avatar
Re: Changing from Auto floor to column shifter
Pretty sure you are correct. Column and Lokar linkage would do it. Or you could find someone selling the stock bellcrank and linkage and use that. Which is the way I went when converting from 3 speed to automatic.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 01-14-2019, 06:05 PM   #3
my67c20
Having basically completed this with my manual to auto trans swap, I would have to second what you are thinking is required. Not sure what you have for a neutral safety switch, but that might be needed as well.
my67c20 is offline   Reply With Quote
Old 01-14-2019, 09:48 PM   #4
Smitty
Smitty's Avatar
Used stock neutral safety switch with auto column. This was when I switched from 3-speed to the 700r4.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Old 01-14-2019, 10:28 PM   #5
Smitty
Smitty's Avatar
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Old 01-14-2019, 11:32 PM   #6
chevyman196669
i just did this same swap last month on my 69 i went from 3 speed to an auto and bought cpp steering column and a lokar kit but i will tell you you will need the longer 26 in rod that lokar sells separate for 16 bucks at summit and trim about 1 in to 2 in off.and it was so simple i would do it again
chevyman196669 is offline   Reply With Quote
