Old 01-07-2019, 01:50 PM   #1
Chris4x4Gill2
Why are my Trans Cooler lines leaking?
I had the TH350 out of my 72 rebuilt. New hard lines for the transmission cooler from Inline Tube used for re-installing. I cant get them to quit leaking from the fitting on the Transmission end.
Should there be a crush washer or seal installed? I though these were tapered pipe thread and would not require a sealant?
"Lifetime" 72 C10 Project
Chris4x4Gill2 is offline   Reply With Quote
Old 01-07-2019, 02:20 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Why are my Trans Cooler lines leaking?
I have always used some type of thread sealant on any pipe threaded items, otherwise I have had leaks (some more then others but almost always some weeping). With tread sealant, they haven't leaked.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-07-2019, 04:05 PM   #3
61K10
61K10's Avatar
Old or new fittings on the trans that the tubes attach to? Lines should be inverted flair that screw into the trans fittings. and no sealant needed. Is your new lines stainless? Try loosing and tightening lines a few times to seat the flair on the tube end. If stainless the metal is way harder than mild steel tube. You might already know this--good luck.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 01-07-2019, 04:55 PM   #4
Chris4x4Gill2
This might be an issue...Line fittings are screwed directly into the transmission housing. Should there be an adapter here? I thought it only required an adapter at the radiator end.
Lines are mild steel.
Old 01-07-2019, 05:00 PM   #5
Chris4x4Gill2
I guess I need this kit?
https://www.inlinetube.com/products/INL10144
This project was mothballed for several years and I don't remember it having adapters on the original lines.
Old 01-07-2019, 06:31 PM   #6
cadillac_al
Yes you need those adapters. Cross your fingers that the threads aren't damaged in the trans.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 01-08-2019, 10:01 AM   #7
SunSoaked
SunSoaked's Avatar
Ouch! If the end of a line is flared, there must be a corresponding inverted flare on the receiving fitting. If not, it's likely a pipe thread and should use Teflon tape or thread sealant. Be very careful not to get pieces of tape in the trans or you'll have other issues.
SunSoaked is offline   Reply With Quote
Old 01-08-2019, 10:22 AM   #8
Chris4x4Gill2
Thanks guys. Fittings are on the way.
Use sealant on the threads or no?
Old 01-08-2019, 10:26 AM   #9
SunSoaked
SunSoaked's Avatar
Yes, sealant or Teflon tape on the threads going into the transmission case, not the line to fitting side.
Old 01-08-2019, 11:00 AM   #10
95 S_Trucker
95 S_Trucker's Avatar
Use thread sealant. I don't like Teflon tape on automotive applications.
I like this stuff:
https://www.permatex.com/products/th...hread-sealant/
95 S_Trucker is offline   Reply With Quote
Old 01-09-2019, 07:48 PM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Was thinking the same thing.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
