01-14-2019, 12:06 AM | #1 |
Junior Member
Gear reduction starter
I bought a gear reduction starter from napa that I'm pretty sure is configured wrong for my '72 402 BB. My block has 3 starter mount holes, so I assumed either straight or staggered pattern would fit. Wrong. when the starter is on, it looks like the edge of the flywheel is about center of the armature shaft. So , I'm thinking this starter must be for a 153 tooth small flywheel and I have a 168 tooth big flywheel. Can a different block be mounted on this starter to make it work?
01-15-2019, 07:59 PM | #2 |
Re: Gear reduction starter
Why not take it back and get the right starter.
01-15-2019, 08:15 PM | #3 |
agreed .... way over thinking it .
big block should be the bigger tooth count gear . you need a staggered bolt pattern unit . straight bolt pattern units = small count . now you say you have 3 bolt holes are we talking on the block face or cast iron bell housing were the starter bolts on ? these are 2 totally different systems .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Thread Tools | |
Display Modes | |
