Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 04-25-2016, 03:08 PM   #1
San Diego Ron
San Diego Ron's Avatar
Rocker Panels
Is it necessary to pull front fenders to replace rusty rocker panels?
San Diego Ron is offline   Reply With Quote
Old 04-25-2016, 04:29 PM   #2
Lanman1972
Lanman1972's Avatar
Re: Rocker Panels
Pulling the fender gives access to the door hinge bolts on the pillar. Removing the door this way makes it easier to put on and off, IMO. I am replacing rockers, cab corners, cab supports and both pillars right now. Usually there is more than just rocker rust.
Lanman1972 is offline   Reply With Quote
Old 04-25-2016, 07:41 PM   #3
swamp rat
swamp rat's Avatar
Re: Rocker Panels
I would say...... Yes..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-26-2016, 10:57 AM   #4
hugger6933
Re: Rocker Panels
Yes the fenders need to come off.
hugger6933 is offline   Reply With Quote
Old 04-26-2016, 12:28 PM   #5
StingRay
StingRay's Avatar
Re: Rocker Panels
Nope you can get them off with the doors on. You will need an air chisel to get the front spot welds that are in behind the fender. It will come off in bits and pieces. You will not however be able to fully spot weld it with the fender still on. If its clean and solid you could use adhesive to attach the new ones. If you are looking to fully clean and repair everything in behind you will need to take it all apart. If you are looking at a quick or temporary fix then it can be done with fenders on.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 04-26-2016, 03:51 PM   #6
San Diego Ron
Re: Rocker Panels
Thanks for all the help here, believe only the rocker is rusted but I'll know for sure once everything has been removed, probably tomorrow. No signs of any rust on inside of cab floor or kick panel. I'll take pictures as I progress.
Old 04-29-2016, 02:18 PM   #7
San Diego Ron
Re: Rocker Panels
Now have the patch panels but haven't been able to prepare rusted areas yet, trip to dermatology for some Liquid Nitro put me out of service, should have taken truck for a shot of the stuff.
C:\Users\Ron\Pictures\2016-04-29 (3)
Old 04-29-2016, 02:49 PM   #8
San Diego Ron
Re: Rocker Panels
Panels came but unable to prepare areas due to visit to Dermatology, hit with the liquid nitro and out of service few days (sun anyway). Should have taken truck in for some deep freezing for its cancer.
Old 01-11-2017, 03:41 PM   #9
San Diego Ron
Re: Rocker Panels
Just wanted to update and show my truck is back together and on the road once more. After these pictures were taken, sanded and repainted truck with another coat, hood; sides and tailgate needed help. (OK now but still some buffing to do, needed to use truck for hauling).
