07-27-2018, 12:16 AM | #1 |
1972 c10 headlight switch wiring
I can every thing EXCEPT actual wiring for my 72 c10 headlight wiring.What i need is what wires are for what? what color is for what? sorry I cant find it anywhere. my switch is-- closest to dash---white -- below is red---to the right is green.right of that is brown. below left is light blue-- right of that is two browns and below that is orange. TY im sure its here somewhere but I cannot find it in faq,s or anywhere on the internet. Thanks in advance
07-27-2018, 07:43 AM | #2 |
Msgt USAF Ret
Re: 1972 c10 headlight switch wiring
Is this what you need?
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
07-27-2018, 02:02 PM | #3 |
Vettevet to the rescue again! almost--- white red dark green same positions my dark brown is right of dk gr--- [IMG]1972 light[/IMG]
07-27-2018, 02:09 PM | #4 |
[IMG]thumbnail 1972[/IMG]
07-27-2018, 02:10 PM | #5 |
sorry for some reason I cant load pic
07-27-2018, 02:14 PM | #6 |
sorry------next to my lt blue is 2 browns together
07-27-2018, 03:05 PM | #7 |
Msgt USAF Ret
The light blue is is fed by the red power wire and is not fused. The brown wires are fed by the orange wire which comes from the fused panel. It is hot with the key off but all lights are fuse by the stop tail fuse.
The parking/marker lights will work where the blue wire goes but they won't be fused. To post a pic click on go advanced and scroll down to the words "manage attachments." Click on that and a window will open with 5 choices to get files. Click on the first one and the window will open to your hard drive. You will have to find out where the pictures are stored and then click on one and it will say "upload", click that and the pic will load in the post. It must be less than 150mb to load.
07-29-2018, 01:41 PM | #8 |
Vettevet AGAIN thank you so very much you helped me in the past and again..TY
09-21-2019, 04:19 PM | #9 |
Replacing my headlight switch, plug, and wiring. Why is my plug from Classic Parts different?
1972 Cheyenne Super |
09-21-2019, 05:22 PM | #10 |
They used yellow instead of LT Blue.
White is for the dome lamp Red is battery 12v LT Blue is the dimmer switch feed DK Green goes to the fuse box. Feed for the dash lights Brown is for the running lights Orange comes from the fuse box. It is 12v ignition switch feed. Hope this helps. |
09-21-2019, 05:26 PM | #11 |
I read the wiring dia wrong. The orange is hot all of the time.
09-21-2019, 06:20 PM | #12 |
Just confused why factory has 2 brown 1 orange, and new plug has 1 brown 2 orange. I just spliced the factory harness wires to the same spot on the new plug. We'll see what happens?...
10-19-2019, 12:04 PM | #13 |
Late and irrelevant to the install. But while going through a square body harness I noticed the colors match what you have. So I’d say they are technically selling a square body pigtail which is why the yellow instead of blue and the double orange
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
10-25-2019, 10:38 AM | #14 |
Old member
I just pulled a complete 68 wiring harness out of my daughters truck to look at it good. Here is her plug.
Just some added info for everyone. I found the main wire connection covered in paint. I don't think anything worked as far as lights! I cleaned it up and got it back to the way it should look.
